Why pull through airhandlers?
I've been trying to understand this for almost 10 years now.
Why do many air handlers, if not most, use a pull through design with the blower on the supply side of the evaporator, instead of it behind the evaporator like on furnace + AC designs?
It seems like besides the airhandler having a tendency to pull air in (often hot attic air), and needing a condensate trap that can often clog it also places the blower in an extremely damp, even wet environment. Why? What is the reasoning?
