What do you think the future of our industry looks like?
RayWohlfarth
RayWohlfarth Posts: 2,091
edited March 2025 in THE MAIN WALL
A friend asked me the other day where our industry is heading and I had never really thought about it. Later that day, I heard some expert on a podcast say that within 5 - 6 years, only half the technicians that are working now will be working. There is already a shortage. So I thought about the future. Looking into my crystal ball, I think the industry will be plug and play. When you call a technician for service, they will come to your house, slide out the inner components and replace it with a new one. The casing will remain. The tech would be there about a hour The old unit could be take to the shop where they can be repaired. I would love to know your thoughts.
Ray Wohlfarth
Boiler Lessons
4Johnpipe
«1
  • DCContrarian
    DCContrarian Posts: 1,588
    Burning oil for heat will seem as archaic to future generations as burning whale oil for light seems to ours.
    Grallertpumpcontrolguy
  • DCContrarian
    For more than 100 years people have been talking about applying mass production techniques to residential housing. There have been some attempts, but for the most part every house is a one-off that is hand built, and crucially for the HVAC, designed and engineered. I could see modular design of the HVAC being part of a broader push to change the way houses are built.
    CLamb
  • delcrossv
    delcrossv Posts: 2,204
    edited March 2025
    What I've seen is the top technicians go into commercial/industrial, leaving residential service to the "boiler salesmen".
  • jesmed1
    jesmed1 Posts: 1,631
    edited March 2025
    I don't think the problem is laziness. The problems are that the equipment is getting ever-more complicated, there aren't enough young people going into the trades, and the gray-haired guys who we need to train the young people are retiring or already gone.
    So it's a supply-demand problem where there is going to be a large under-supply of well-trained techs who can understand and fix this complicated stuff.
    sdodder
  • Intplm.
    Intplm. Posts: 3,160
    edited March 2025
    I don't believe the time frame will be as little as 5 to 6 years. Maybe within twenty years will there be a more saturated beginnings of plug and play.
    The advent of plug and play will also usher in the less capable. Meaning there will be little to no trouble shooting skills or common sense that will be applied when there will certainly be a need for it. In the future, all one would need to do is look at a video or some other means of direction and believe that they have solved a problem, (Sounds desperately familiar already.)
    This type of issue will show itself much more in my life time and most likely will be some sort of common practice in the decades to come.
    Long Beach Ed
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    Very bright mad Dog
    hot_rod Posts: 28,699
    Agree, this has been going on for the 40 plus years I have been in the trades.
    You'll find this exact conversation at the mechanics, electrician, any trade chatroom.
    Intplm.PeteAsdodder
  • ratio
    ratio Posts: 4,344
    The only real question is how much worse is it going to get before it gets better.
    EdTheHeaterMan Posts: 12,940
    I read an article about doing an oil burner tune up on a European boiler consisted of quick connect oil lines and the 2 bolts that hold the Riello oil burner on the flange with a 3 wire plug for electrical connection. The burner gets swapped out in about 3 minutes, the flue passages are inspected and vacuum cleaned (rarely needed) if there is a large enough build up. The whole process takes about 20 minutes including the combustion testing and paperwork (that is paperless by the way).
    The oil burners are cleaned and tuned up at the shop with the specifications on file in the customers records. there is rarely any soot involved in these tune ups. So the technician with the brains and the skills are at the shop doing all the detailed work. anyone can look at the chamber for soot an vacuum it out if needed. The replacement burner is preset and adjusted for the best operating parameters for the year. You need less top notch technicians with this program and you can offer service to more customers this way.
    delcrossvLong Beach Edsdodder
  • Mad Dog_2
    I think it's very slowly catching on with the Suburban kids AND the inner city kids that skilled trades are great option. Mad Dog
    sdodder
  • Mad Dog_2
    Ha ha...The Parts Cannon...aka Shotgun approach..Mad Dog
    edited March 2025
    It isn't just trades. i needed an accountant and had a lot of trouble finding one and they are all constantly overworked. It is treating services and service workers like they are an expense to be reduced to as little as possible. Where i work i see everything support related treated as we want to spend as little up front with no thought about how much more that will cost to support and lost work from the people trying to use that service. They are never looking for the best solution, they are always looking for the cheapest solution. Even if you get paid reasonably well constantly implementing the compromise solution is very much not satisfying.
    Mad Dog_2PC7060EBEBRATT-Ed
    edited March 2025
    there are a lot of people just living with terrible systems that were installed when the house or commercial building was built.
    CLamb
  • Long Beach Ed
    Long Beach Ed Posts: 1,851
    edited March 2025
    We're moving away from private home ownership, at least in the metropolitan areas and away from central heating plants.
    In many cities and suburbs, oil and gas are being banned. With the obscene price of electric generation, I see more individual room by room Chinese heat pumps and resistance heaters subsidized by government - according to income - as is done in NYC public and subsidized housing projects and soon in private homes by NY State.
    More plastic and sheet metal junk replaced every six years and thrown in landfills. Just another increased expense for the homeowner.
    Mad Dog_2
  • At least in my area, I haven’t found many people that want to learn what we do. Part of it is that many don’t like to get dirty. I’m filthy when I get home.
    And I don’t see my suppliers offering classes like they used to. I guess it’s all online now.
    And what happens when the economy goes south; the next recession? When there are less jobs, people still need their boilers fixed when they run out of hot water or their house is cold. People will come back to the trades. It’s been a fallback forever.
    Electric cars electric HPs server farms, bitcoin harvesting centers around here are all coal powered. Tons of coal powered Teslas running around here.
    In fact another new coal plant is being proposed south of me in a small farming community
    However big push back from the all the locals
    Burning coal to cool our buildings, power the “green” cars, what a country😂
    JUGHNErick in Alaska
  • delcrossv
    edited March 2025
    We're moving away being moved away from private home ownership, at least in the metropolitan areas and away from central heating plants.
    FIFY.
    There's growing resistance to the whole "you'll own nothing and be happy " edict.
    Long Beach Edjim s_2
  • Intplm.
    edited March 2025
    I so very much agree. Yet so many take it for granted.
    Mad Dog_2
  • pedmec
    pedmec Posts: 1,488
    From my perspective it's upper management that's the problem. When smaller companies try to transition from a smaller company to a larger company they forget about the technician. All they look at are the numbers and they reduce the technician from a real person to a number. Who wants to be treated like a number. That's all the larger companies do is talk about numbers and how much revenue they have. When you minimize the technician you minimize his ability to not only help the company but also whether he wants to stay in this field. eventually the technician bad mouths the field to the younger generation and then the younger generation doesn't want to do what we do.
    Management forgets it's the relationship between the technicians and the customers that keeps the company strong. The ability of a technician to not only fix the issue at hand but to develop a trust with the customer that will keep them calling. Management thinks that calling technicians into there office with HR and whoever else to try and prove a point is very counter productive when a simple phone call to the offending technician would have been more productive. I honestly can't tell you how many technicians that i really respected left the field but i see it month after month. they are tired of being minimized by corporate CEO's who thinks it's management that has created the company.
    mattmia2Intplm.Mad Dog_2GroundUp
  • DCContrarian
    The biggest trend in the HVAC business right now is private equity firms buying up family-owned firms. Some people argue that many of these firms weren't very professionally managed, and their may be some truth to that. But private equity ownership doesn't tend to be good for employees or customers, or anyone other than the investors.
    delcrossvMad Dog_2
    People don't quit their companies, they quit their bosses. Doesn't matter the size, type, profitability, ownership of the company
    mattmia2CLamb
  • SlamDunk
    SlamDunk Posts: 1,831
    edited March 2025
    I can tell you what the future will look like. I am witnessing it. Near net zero homes. Even carbon zero homes and companies. Super insulated buildings, & where possible, solar power and geothermal hvac...Even heatpumps where you wouldnt think they would work. All heavily computerized. Biofuels/Biogas where possible: See Novozymes. Overture, the maker of future supersonic jet BOOM! Using renewable biofuel. So, if I were starting out, in an area of moderate wealth, I would get into HVAC programming and renewable energy. It is early stages but the technology works.
    DCContrarianPC7060
  • Hi, I'd encourage tradespeople to learn the business side of things right along with the trade part. That would give them the option of being self-employed, which is a much more stable place to be. Until recently, schools didn't teach financial literacy, but it's essential if you want to be in control of your money. The sole owner who knows his or her costs is going to be hard to compete against if you're a top-heavy, or purely profit-driven organization. Specialization is a plus also. These things can make the trades more attractive than just a dirty job that's stressful and doesn't pay all that well.
    Yours, Larry
    delcrossvIntplm.mattmia2CLamb
  • DCContrarian
    This is already happening. With the newest building codes an all-electric net zero house is very attainable in most of the country. I wish I could find the link, but there was recently a story about a net zero affordable housing development in Massachusetts — which isn't a mild climate. A developer is building a 4500-unit net zero community in Fort Collins, CO — which isn't mild either:
    https://www.greenbuildingadvisor.com/article/developer-plans-largest-net-zero-ready-community-u-s
    Where I am, Washington, DC, all new construction has to be "net-zero ready" by 2026. And “on-site fuel combustion” for heating and water heating in new buildings will be banned.
    https://dcist.com/story/22/07/14/dc-natural-gas-ban-net-zero-carbon-new-construction/
    Steamhead Posts: 19,007
    Courts have overturned several of these fuel bans.
    Semi-retired
    Mad Dog_2delcrossvjim s_2
    It would be interesting to check in on these jobs after a couple winters of run time.
    -30C design, 41C SWT (105F)
    PV, wind, and diesel supply power to the area.
    There is also an oil fired back up boiler.
  • RayWohlfarth
    Wow lots of crystal balls here. I also wonder if locally owned hvac companies will be a thing of the past, replaced by large corporations headquartered in some office building
    Ray Wohlfarth
    Boiler Lessons
    clammy
  • SlamDunk
    I manage the maintenance of two net zero buildings (kind of a boring job) with two more coming online within the next five years. They are six and two years old and when we have local power outages, these buildings don't even flicker. They switch to battery.
    A developer, nearby, built a row of netzero homes (about six on a city street). They all sold before they were built for a cool $1.95 million each. Like I said, still early stages but the guys making the most money are the programmers that integrate these systems. It is pretty exciting to see what is coming down the pike. There is nary a homeowner or building owner that doesn't look for ways to reduce energy costs.
  • Lance
    Lance Posts: 344
    I'll be brief as I do not have the time. If we are going to have service industry capabilities, it must come to the Master's to take responsibility. Apprenticeship has always been taught by the master. Many got lazy or feared if they even licensed their apprentices, they would lose them. Well look where we are now. We gave it to the education system and they blew it off and sacrificed the very incubator of shop class and Votech training.
    I recently sought out my local high tech school and met with two instructors, principal. I offered a partnership with them to provide a future for those students. They have done a good job, but they agree with me, it is often too late to send a graduate into a trade, they have little experience in based on one 1 hour class a day which is never enough. That a career path in our trades needs a commitment to place all their training staring no later then 11th grade. Especially when so many have fewer experiences due to lack of shop classes, which must be brought back to our schools starting in 7th grade! Its time to put our tax dollars to invest in shop training to rebuild our work force.
    I learned education begins after high school graduation. In our trades it is always changing. if we are to save our service economy in the US we must take charge. Following the Parrado rule and realize college is for the top 20% who can pay cash and the rest of us, the 80% needs to use our skills and on the job training as we have learned with night school to a path whereby companies pay the tuition and the grad graduates again with a journeyman license. All while making a living and with no school loan debt. It takes a 1,000.00 sale to make 50.00 on a 5% net profit. Imagine a 10,000.00 debt is just 5% of a 200,000.00 sale. Remove the debt expense and earnings can better afford a living. I have been a member in several organizations. We business people learned we had to grow our own, we built the programs, changed the law in Maryland, and this works!
    Training your people will not lose them but it will retain them. Without training you will lose them anyway.
    I succeeded because I took charge of my own education at grade 11. It changed me for the better. I realized my time was more important then my instructors / teachers. How dare they miss a class when I was ready to learn. I learned as if to teach it. It made me rise to the top. This is what we must offer to the youth if they truly want to set goals to live a good life. and we want to keep our customers happy and our profits worth all the efforts.
    Lance
    RTWdelcrossvrick in Alaska
