Repair or Replace Gas Boiler
Hi , my 30 year old teledayn lars
FHW natural gas
boiler blew up the t & p valve , copper tubing it was soldered on right off the boiler .
Prior to that , the second floor baseboard lost its heat.
First floor baseboard was still giving off heat. Boiler operating and heating.
Running like that for 4 weeks.
When one evening a loud explosion occurred in the basement.
Upon checking, I found the boiler not running and a little water around the boiler.
Looking further, I saw that the T & P valve had blown right off the boiler top.
Is the boiler repairable ?
By repiping a new T & P valve to the boiler and flushing and purging the air out of the first and second floors baseboards.
Then restart the boiler and do a boiler check.
( What causes the second floor baseboard to lose its heat ? )
Air in the system ?
Water filled evaporator tank ?
Clogged water feed valve ?
Thanks
John M.
It may or may not be salvageable — I wouldn't say repairable. I wouldn't bother; too much more or less difficult to detect damage may have been done by the overpressure event.
In fact, I would scrap it, the expansion tank, and any trim, such as the defective pressure relief valve, the low water cutoff (if there even was one), aquastat controls — the lot. Again, not worth the time and effort to find out which redundant safeties failed.
Then start all over again.
You got a long run out of that Tlyne-Laars...That's not even a company any longer, but Laars make a really nice replacement. Mad Dog
3 -
Could be the expansion tank was waterlogged and the relief valve was scaled shut. Could be system was low on water because the pressure reducing valve failed and it had a leak of some sort and the boiler got low enough on water that the boiler heated the joint on the relief valve to the point where it melted the solder because part of it was dry firing. In either case it would be best to replace the boiler after either event.
Did water pour out of the relief valve piping?
* Thank you
Yeah The T & P valve and valve pipe it was affixed to shot right out of the top of the boiler . . Exploded boom.
* Thank you
* Thank you
I tend to agree .
Get a replacement gas boiler.
Any suggestions on brand gas boiler.
Thanks
* Thank you
That Tele Larrs boiler was a good boiler. 30 + years old.
It was used in heating swimming pools.
Thanks
Thank you
Sounds about right on.
Probably scale clogged the
Valves And T & P.
Low Water - then hot steam -
Boom - T & P Valves and valve pipe shot out - exploded.
Looking For Replacement Gas boiler. Burnham , Weil McClain , Crown , Utica . .
Thanks
I assume it uses a HX to heat the pool water?
Laars makes a great product & fantastic tech support & warranties. Mad Dog
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
