Air vent substitute??
I have 12 cast-iron American radiators that work perfectly. Recently, however several of the air vents on the middle floor radiators have frozen shut. My plumber tried to drill one out, but it didn’t work and I stopped him because I don’t want the radiator ruined.
Is there another way to vent this radiator? Like in the upper plug? Any idea ideas or suggestions?
The middle floor tends to get air in it unless you flush it. We used to flush it and vent it and now we can’t.
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Wait…is that 1/8" port in the upper left of your photo that looks like it was hit with a torch the place where the vent was?Ignore my irrelevant question, thank you!NJ Steam Homeowner.
The drilling is way off center, but shouldn't there be an existing opening to work with? That looks solid.
i can't tell, the pic isn't high enough resolution. it could be the screw part of the vent broken off in the body of the vent.
Anyway@RobinInCalithe reason I was asking is that's the wrong location for a vent if that's where it was. There should be a port that is about 2/3 down on that side (possibly both sides)Ignore my irrelevant comment, thank you!NJ Steam Homeowner.
Well don't I feel dumb! Thanks @mattmia2
