xxx
RobinInCali
RobinInCali Posts: 56
edited March 17 in THE MAIN WALL
xxx
  • RobinInCali
    edited March 17
  • delcrossv
    delcrossv Posts: 2,204
    edited March 2025
    hot_rod Posts: 28,756
    you should be able to drill and re-tap thise vent ports. You may need to go a size larger
    You can get 1/4 & 3/8 sizes
    delcrossv
  • delcrossv
    Drill and re-tap is the standard procedure for this.
    bburd
    ethicalpaul Posts: 9,092
    edited March 2025
    Wait…is that 1/8" port in the upper left of your photo that looks like it was hit with a torch the place where the vent was? Ignore my irrelevant question, thank you!
  • Long Beach Ed
    Long Beach Ed Posts: 1,851
    edited March 2025
    If this is steam, there should be a boss half way up the middle column that can be drilled or a plug there that can be removed. The top one is for venting air from a hot water radiator.
    That, too can be drilled out by any competent mechanic. You use a center punch first to guide your drill.
    Mad Dog_2
    HVACNUT Posts: 7,796
    The drilling is way off center, but shouldn't there be an existing opening to work with? That looks solid.
    mattmia2 Posts: 18,420
    i can't tell, the pic isn't high enough resolution. it could be the screw part of the vent broken off in the body of the vent.
    the vents are usually brass, so hit that with a file or small grinder to flatten it then center punch
    techforlife
    pecmsg Posts: 7,644
    From the 1st picture it looks like brazing rod and burn marks from heating with a torch!
    edited March 2025
    Anyway @RobinInCali the reason I was asking is that's the wrong location for a vent if that's where it was. There should be a port that is about 2/3 down on that side (possibly both sides) Ignore my irrelevant comment, thank you!
    This is hot water. It is the right location for the bleeder/vent.
    Well don't I feel dumb! Thanks @mattmia2
    reggi
  • ChrisJ
    ChrisJ Posts: 17,772
    I would use a grinder / dremel and grind that surface as flat as I could get it, then center punch / drill it.
    You need to be a little delicate because you don't want to crack the cast iron.
    mattmia2delcrossvtechforlife
