How to calculate EDR for dummies
RTW
RTW Member Posts: 285
A lot has been posted on knowing EDR to match boiler size and thought this Link would give residential homeowners a better understanding on how to measure EDR on their own
radiatorest.pdf
I read in a post the other day the EDR # should correspond to the Steam Sq. # on the boiler label plate
Im an amateur with steam heat, so don't hold me to this info. and follow professional advice
All the best,
RTW
Ironman
  • delcrossv
    delcrossv Member Posts: 2,204
    edited February 2025
    The book Every Darn Radiator is more accurate. But this will "ballpark" you.
    Not sure about the x1.25 to get boiler size as SqFt of steam on the boiler plate already includes a 33% pickup factor. Adding another 25% would get you well oversized.
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    One of the problems with the guide at
    radiatorest.pdf
    is that it only mentions one type of tubular radiator. In fact their are two and they are greatly different. The first version of tubular radiators had thicker section, mearsuring 2.5" on center, the same as most column radiators. Then, the slenderized version came on to the market with a section dimension of 1.75" thick.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    bburd
  • Dave in QCA
    Another good EDR guide comes from an old ASHRAE guide book. I have been using this guide since 1982. More exact EDR ratings from the manufacturers is even more accurate and Dan has a ton of those in his publication, EDR - Every Darned Radiator.
    random12345
  • Pumpguy
    Pumpguy Member Posts: 806
    The EDR is equally needed when sizing vacuum and condensate pumps for 2 pipe systems.
    Whenever I'm asked about replacement pumps or system problems, and ask what is the system's EDR, no-one yet, ever, has given me this information based on an actual survey of the radiation.
    So that leaves me with having to rely on the steaming capacity of the boiler plant, or the pumping capacity of the old equipment.
    And then they wonder why the new equipment doesn't work any better than the old stuff did. Doing the same thing and expecting a different result is………………
    delcrossvDave in QCA
  • RTW
    Could use a YOUTUBE video showing how one measures a radiator to get an accurate number to establish EDR in steam heating system
    All the best,
    RTW
    jringel
  • dabrakeman
    dabrakeman Member Posts: 1,020
    For a simple sheet I liked this one. Includes the thin tube variety.
    random12345
  • Jells
    Jells Member Posts: 649
    Thanks, I was sure I'd seen one with 'depths' dimensions but could not turn it up!
    Stupid question: do all the mains and risers not go into the EDR calc in any way? There's a lot of surface area there!
  • delcrossv
    That's the 33% pickup factor included in the boiler rating.
    bburd
  • Jells
    Ah, I kept seeing that phrase used but had no idea what it actually meant!
    delcrossv
