Future work.
  • ratio
    ratio Member Posts: 4,172
    Lots of service room there. Oughtta be a quickie.
    Harvey Ramer
    pecmsg Member Posts: 6,742
    One unit blowing into the other?
    That’s not going to work well!
    IronmanHarvey RamerGGrossdelcrossv
    and the second unit blowing into the 3Rd
    Hot_water_fanGGross
  • Ironman
    Ironman Member Posts: 7,842
    Good to see ya again, Harvey.
    Bob Boan
    Harvey Ramermattmia2
    EBEBRATT-Ed Member Posts: 19,411
    I see high head pressure
    Harvey Ramer
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,281
    Right! Hold my beer and watch me turn a 17 seer VRV unit into a 2 seer unit. (not seer 2)
    Mad Dog_2
  • GGross
    GGross Member Posts: 1,720
    Look they added a little bit of pad, most likely to get the manufacturers minimum separation lol
    watch them pour more pad so they can stack more units in there, surely that will fix it!
  • PC7060
    PC7060 Member Posts: 1,750
    recently saw a house with two Lenox units located 6” apart. Is capacity reduced linearly; 1/4 airflow blocked = 25% reduction in capacity?
    mattmia2 Member Posts: 15,368
    It depends a lot on how the discharge. if they all discharge up it probably is a little bit more than negligible. When they discharge in to each other then it is like the second unit is working in 120 ambient. That will raise the head pressure to raise the delta t enough to be able to transfer the heat to the warmer air.
    PC7060GGrosshere_to_learn
    hot_rod Member Posts: 26,471
    At least they have colorful blocks protecting the space😉
    mattmia2GGross
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,373
    C'mon guys…we can fit one more in there...Mad Dog 🐕
    GGross
  • ratio
    Funny story: a while ago, when I was a wee li'l electrician, I did a job when the engineer had put some 6-8 condensers in a roof well—with no clearance between them. When that oops came to light, 3-4 had to be relocated to a different roof. We got the RFP, got the change order blessed, did the work, & got the change order paid. Towards the end of the job we got an email from the engineer to the effect that "We were going over this change order & it seems a little high. What are you going to do, lower your price?" I can only imagine that they reached a point where they were going to have to eat the cost. I suggested that we reply "We were going over this change order & it seems a little low, what are you going to do, pay us more?", but I don't think we did.
  • GGross
    Mad dog! I didn't know you were an engineer! 😂
  • Intplm.
    Intplm. Member Posts: 2,806
    Maybe install a hybrid water heater close by and set the selection switch to hybrid. That should make up for the installation issue.
    NOT!!!
