The "I don't care" guy.....
"Hey...bro...what do u want??? It aint leakin' and the faucet works!!" Mad Dog1
I think it more likely a plumber wasn't involved, and whoever tiled behind the sink removed it for tiling and reinstalled when they were done.0
Of course.Alan Welch said:I think it more likely a plumber wasn't involved, and whoever tiled behind the sink removed it for tiling and reinstalled when they were done.
Plumbers never do bad work.
6 -
Sometimes you run into this on electrical. The first thing I used to do is ask what the wall finishes in the bathroom and kitchen will be, as well as the rest of the house. Are we going with 1/2" sheet rock or is it tile or something else. You need to know to get the boxes set the correct depth. The front edge should be flush to no more than a 1/4 back in noncombustible material and flush in combustible material.
Sometimes after the boxes are all nailed in and the rock is hung they change their mind and put-up tile or wood paneling.
You can't move the boxes with the rock up so you end up with rinky dink box extensions or a crappy job.
Not always the plumber or electricians fault. although crooked drain could have been easily fixed with an elbow or maybe 2.1 -
Where are the chrome nipples and escutcheons? They have this handy thing called a split ring escutcheon if you forget to put it on your nipple when you are assembling the nipple and valve. I'm sorry but work like that makes my skin crawl.0
And then, the rare, I DO CARE GUY! Another public bathroom.
Mad Dog
3 -
@ratio Those escutcheons rust quite easily. It's probably not used per se. I think @Mad Dog_2 is showing is work that has been done sometime ago and not recently.0
I was making a funny. With raising three boys, I know all too well what happens to any metal near a toilet.
Professionally speaking, the offset is rather well done. It takes skill to get it to run plumb like that.
It's urine.damage ...easy fix..split escutcheon...isnt that bend nifty? Mad Dog2
Mad Dog_2 said:It's urine.damage ...easy fix..split escutcheon...isnt that bend nifty? Mad Dog
3 -
When I first started in mid 1980s, you could still get solid brass, chrome plated pipe escutcheons. 7 out of 10 plumbers can't spell escutcheon....5 out of ten leave the B out of plumber..ha ha. Mad Dog
Mad Dog_2 said:When I first started in mid 1980s, you could still get solid brass, chrome plated pipe escutcheons. 7 out of 10 plumbers can't spell escutcheon....5 out of ten leave the B out of plumber..ha ha. Mad Dog
2 -
After many attempts at bending " flexible " CP or rough brass supply tubes I became quite good at it; especially after several confrontations with my boss about wasted time & materials.
I was a 90 lb weakling when I started in the trades so it took a while to develop the hand strength & finesse needed to execute picture perfect offsets.
I stopped using plastic top nuts after several split & flooded the buildings; residential & commercial. Night time pressure spikes on public water supply systems, and residential pressure switch failures coupled with quick closing ballcock water hammer can do a lot of damage including fractured toilet tanks...
Agreed. I have 2 switches top of my cellar stair. My dad visited and said "I think I flipped the wrong switch". He had and it was too easy to do. I put duct-tape to deter further flippery that visit, got the red metal strap to go over permanently, then got fancy with a Big Red Paddle STOP switch. Nobody thinks it is a light-switch!Mad Dog_2 said:It's a Guard ! Thats it..
I got the "not saw-safe" model. If it said "Magnetic" it would latch-out on power failure, which is good if your thumb is in the saw, but not usually needed for tame burners.
Found another one....I'd be afraid of an arc fault that used the gas pipe as it's victim and go BOOM!!! May not happen in a Million years, but...... Mad Dog0
I'm raising an 8 foot length of fin tube in preparation for hardwood floor. The house was re-plumbed with fin tube & PEX before I bought it. The fin tube in this room had 4 screws holding it to the wall though it was loose. Not one of the screws was into wood. I guess it looked OK in the beginning.
Stud-finders cost $$ you know! If you put enough screws in to the sheetrock, It'll hold until after the closing. That's that mentality of "that guy." Mad Dog
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
