Air Vent Stuck
Giants9890
Member Posts: 12
Hi Everyone, amateur homeowner here with an old home using steam heat.
An air vent on my return line is not letting air so it needs to be replaced. I cannot get this piece to budge so I can replace it. I have a pipe wrench, extender, and just tried to heat it up with a torch. I’m afraid to pull too hard and break a pipe or cause damage.
Photos of the area and the new piece I am trying to replace it with.
Any suggestions, please?
The coupling may come undone from the pipe more easily than the vent from the coupling. Try heating the coupling (but be darn careful -- you're very close to that foam insulation, which is flammable!) and then using two pipe wrenches -- one on the pipe and one on the coupling -- to free it.Br. Jamie, osb
Along this same line, the pipe may also come free from the elbow easier.
You don't need that long pipe anyway, water isn't going to go up there.NJ Steam Homeowner.
Thank you for your help.I still can’t get the coupling or the pipe on the elbow to budge. It looks like someone used paint on these one or more times. I think I have some rust too.
I was just going to say, the solution to every problem is a bigger wrench!
I am going to buy a bigger pipe wrench. There’s a 24 inch, 36, and 48. Do I need to get one as big as 48 inches? Cost is significantly more for the larger wrench and wondering if I can pull it off the with the 24 inch. Thanks again.Current is only 12 inches0
For those fittings I'd say 18 inch would be plenty
- 117 Geothermal
