Air Vent Stuck
Hi Everyone, amateur homeowner here with an old home using steam heat.
An air vent on my return line is not letting air so it needs to be replaced. I cannot get this piece to budge so I can replace it. I have a pipe wrench, extender, and just tried to heat it up with a torch. I’m afraid to pull too hard and break a pipe or cause damage.
Photos of the area and the new piece I am trying to replace it with.
Any suggestions, please?
    The coupling may come undone from the pipe more easily than the vent from the coupling. Try heating the coupling (but be darn careful -- you're very close to that foam insulation, which is flammable!) and then using two pipe wrenches -- one on the pipe and one on the coupling -- to free it.
    Giants9890Ironman
    ethicalpaul Member Posts: 8,933
    Along this same line, the pipe may also come free from the elbow easier.
    You don't need that long pipe anyway, water isn't going to go up there.
  • Giants9890
    Giants9890 Member Posts: 12
    edited December 2023
    Thank you for your help.
    I still can’t get the coupling or the pipe on the elbow to budge. It looks like someone used paint on these one or more times. I think I have some rust too.
  • Ironman
    Ironman Member Posts: 7,927
    Bigger wrenches, two men, cheater bar. It will come loose.
    Bob Boan
    ethicalpaulGiants9890
    I was just going to say, the solution to every problem is a bigger wrench!
    Giants9890
  • Giants9890
    edited January 2024
    I am going to buy a bigger pipe wrench. There’s a 24 inch, 36, and 48. Do I need to get one as big as 48 inches? Cost is significantly more for the larger wrench and wondering if I can pull it off the with the 24 inch. Thanks again.
    Current is only 12 inches
    For those fittings I'd say 18 inch would be plenty
    Giants9890
  • bburd
    bburd Member Posts: 1,318
    You can rent a larger wrench.
    Bburd
    Giants9890
    Don't forget you need two -- one on what you want to unscrew, and one on what you DON'T want to unscrew.
    Giants9890
    EBEBRATT-Ed Member Posts: 20,482
    Harbor freight has cheap wrenches that are ok for occasional use. Or a tag sale
    I would buy 1 14" & 1 18" you will use those sizes more often and you can put cheater pipes on them if need be
    ethicalpaulLarry WeingartenGiants9890
