Piped totally wrong
Steve_210
Member Posts: 647
But the customer says it works
I’ve come to realize the term “works” is quite subjective.6
This. You don't say what model it is, but it looks too big for 2" pipe.KC_Jones said:I’ve come to realize the term “works” is quite subjective.
Consulting1 -
Sorry guys, egh 95 should have a 3 inch Header0
You don't know what you don't know. When I moved into my first steam heated home 22 years ago I turned the heat down to 50 when I went to bed and back up to 68 when I got up. Made a lot of funny noises but "it worked". Yes the boiler was 40% oversized and I thought the steam coming from the vents was just a neat way to humidify the air.1
It works no serious water hammer to talk of at least not that I heard.
Probably very inefficient as Steam is fighting to get into the mains
Two. Main things.
1 homeowners really don’t seem to know the difference
2 , the guy was able to do it a lot cheaper than do it the right way0 -
Two. Main things.
This is something I've wondered about for many years now.
If an improperly piped boiler is inefficient.
Where is all of that extra "wasted energy" going? The block and piping can't be dissipating more because they aren't hotter, at least not any significant amount? So where's it going? When someone talks about these I always imagine a 5-10% drop, that's a lot of energy to get rid of especially on an EGH-95.
@Jamie Hall ?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The steam isn’t fighting anything in this header if water isn’t getting carried into the header.
like Chris implied, even then, all the energy is going into the house anyway.
when my old boiler would surge, it was like a loop of hot water going into the main and back down the return.
but all that water was 212F and steam was released and made it to the radiatorsNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 52 Industry Classes
