Another Moline System
Ironman
Member Posts: 7,753
Jamie Hall said:Very nice. That cellar looks like a nightmare to work in...It was. Other than the small pit the boiler was in, everything was uneven dirt covered with 4mil poly which was slippery. No functional lights and head knocker’s everywhere.
The object wrapped in plastic to the right is the old coal boiler which was just moved to the side by the previous installer.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
Some of these old houses down here date back to pre-civil war times and have a fire place in the cellar which was the servant quarters.
This one had a flue opening in the other side of the cellar. Not sure what that was for.Bob Boan
I'm sure you could match the header up to the boiler wrapped in plastic.EBEBRATT-Ed said:The old boiler was a disaster.
Cities condemned homes without heating systems. Houses were rehabilitated by digging out enough space to instal heater. But Moline was cadillac grade so one would expect a nice basement?mattmia2 said:In Michigan real estate they call an area that is more or less a crawl space with a bit more head room a "Michigan basement". It isn't really habitable space and usually has a mishmash of floor elevations and usually dirt floor.
Cities condemned homes without heating systems. Houses were rehabilitated by digging out enough space to instal heater. But Moline was cadillac grade so one would expect a nice basement?Bob Boan
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
