Are there seriously no leveling shims I can just buy?
zooba
zooba Member Posts: 8
I don't want to cut wooden squares or circles. I don't want to use coins. I want a little heat and rot resistant cup I can just slide under the foot without struggling. And it should be just broad enough to sit on top of the depression on the floor caused by rot on a couple of the rads. Like, why do no rad companies sell these things?
This is for one-pipe steam radiators.
I've searched the internet and this forum and gotten no real solution.
    ethicalpaul Member Posts: 8,198
    Steam rad companies? There is like one :joy: Suck it up and cut some circles :smile: Don't worry about heat resistant. Anything that can support the weight is going to be heat resistant enough.
    PeteA
  • ChrisJ
    ChrisJ Member Posts: 17,097
    I bet those could be 3d printed........
    Hmmmm
  • KC_Jones
    KC_Jones Member Posts: 5,912
    2014 Weil Mclain EG-40
  • AdmiralYoda
    AdmiralYoda Member Posts: 745
    If you want to buy, not make... go to McMaster.com and start looking at aluminum discs. You can usually find aluminum or other metals cut in various diameters and thicknesses. Square, Rectangles, Circles, etc.
    Just an example. Scroll to the bottom.
    https://mcmaster.com/products/discs/multipurpose-6061-aluminum-rods-and-discs-7/
    mattmia2zoobaTheDavidDDuncan
  • Tommi68
    Tommi68 Member Posts: 56
    Keep a stock of plated fender washers in your tool bin. 3/8” fender washer is 1-1/4”dia. Stack as many as needed, unless there is a structural issue to fix first.
    Jamie Hall Member Posts: 26,897
    There is an incredible variety of furniture glides and feet sold all over the palce. Surely one of those would work?
    ethicalpaulCLamb
    mattmia2 Member Posts: 15,782
    Washers will cost a lot less than "metal disks". There are some washers that are designed to interlock and stack.
  • neilc
    neilc Member Posts: 3,137
    hockey pucks
    known to beat dead horses
    CLamb
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Plastic checkers. You get to choose the color.
    Retired and loving it.
    clammymattmia2EdTheHeaterManMikeAmann
  • ChrisJ
    Any color you want too.
    As long as it's red or black.
    zooba
  • clammy
    clammy Member Posts: 3,243
    I use felt pads for chairs legs Or the plastic round furiture disc for moving couches for free standing rads among other things and if they have a cover then plastic shims ,washers or simply some 1 x3 if it really needs a lot of rise . If the home owner wants some thing fancy well then it on them I’m just there to make it work correctly and correct things from rad legs digging in flooring or house settling . Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,088
    Hey @Chris You can offer to paint them to match for a price. I prefer sky blue pink. LOL
  • ChrisJ
    edited December 2023
    You can usually paint the printed parts, but I try to print whatever color is best without painting it.
    Maybe mix some purple and red in there?
    Probably someone molding checkers in other colors out there.
  • zooba
    Thanks everyone for the comments. I've summarized some options that look decent:
    I did manage to find furniture foot stops; most are too thick and not interlocking so it was hard to find. One ok option is the "stable the table" brand. These are 1/8" thick and nesting. 12 pack for $19 means $1.58 apiece. The downside is the 2.2" OD, awkwardly large, but they are brown to blend with the floor.
    https://amazon.com/Stable-Multi-use-Furniture-Protector-Loveseats/dp/B0BMW95691
    Metal disks or washers - tons of options but you have to hunt a bit. Most are too thin (a tall stack would be unstable and annoying to set up) or have too big of a center hole. For reference, a quarter is 0.955" OD and 0.069 thick. The aluminum or steel disks (not washers) from McMaster were minimum 1/2" thick, too thick. Most stainless washers are really thin, 0.05" typical.
    Black steel washers, 1" OD, 0.28" ID, thickness 1/8". $1.18 apiece. https://mcmaster.com/92140A112
    Fender washers - seems like a great choice. Available from any hardware store. Dimensions are good. 1.25" OD, 1/4" ID, 1/8" thick. https://homedepot.com/p/Everbilt-1-4-in-x-1-1-4-in-Zinc-Plated-Fender-Washer-100-Pack-804790/204276327
    Interlocking washers - couldn't find it.
    Stamping blanks - usually too thin.
    Wood disks - available from Michael's. 1.5" OD. Thickness? Not listed, looks to be at least 1/8". Wood? It's a mystery. Price? $0.22 apiece. https://michaels.com/product/wood-discs-1-12-10049505
    Wood disks from woodpecker's - shipping isn't free, but it's a guaranteed hardwood (birch) and it comes in various sizes, super cheap from $0.12 - $0.21 apiece if you buy at least 25. https://woodpeckerscrafts.com/wood-circles-wooden-discs/#/filter:custom_material:Solid$2520Birch
    Similar wood disks from American Woodcrafter's Supply. https://americanwoodcrafterssupply.com/catalog/wooden-discs-wooden-circles/wooden-discs-wooden-circles/
    I ended up buying a bunch of different sized pieces from Woodpecker's. Total was $21 including shipping for 100 pieces.
    WaherdabrakemanRobert_H
  • Waher
    Waher Member Posts: 367
    OCS sells 2" & 3" cast iron pedestals that could be filed https://ocsind.com/. Marble door thresholds can be tapered with emery cloth.
  • SlamDunk
    SlamDunk Member Posts: 1,793
    edited February 2024
    I use laminate flooring stepped wedges on just about everything not level.
  • DougP
    DougP Member Posts: 13
    Now in 3rd heating season with crutch / chair tips on Am Rad Co rads. Started with rubber now use silicon 1 1/8 inch. Before using tips had problem with improvised shims being pushed out from under the radiator no longer an issue, add washers inside for height.
  • lukewatts
    lukewatts Member Posts: 9
    Sorry to be so late to the show on this @zooba
    Did you get these sorted in the end?
    How high did you need the shims to be?
    We have stock of some pedestals at Castrads...
    https://castrads.com/us/
    They are only 1" or 2" in height though (not adjustable). You could have the milled down to the specific height you'd need though.
    See image of 2" pedestals below
    Long Beach Eddelcrossv
  • MikeMan134
    MikeMan134 Member Posts: 5
    I just used regular wooden shims on my radiators, similar to this: https://www.homedepot.com/p/8-in-Cedar-Shims-12-Pack-WSSHW08/300723328
    Adjustable for any height, and easy to cut off the excess so it's minimally visible.
  • zooba
    Update after the heating season is over, and again thanks to everyone who responded.
    I did buy the disks in 1/8" and 1/4" thicknesses and either 1/2" or 1" diameter from Woodpecker's supply. I am very happy with the result. A couple of points:
    • I used 1-4 pieces stacked under each foot depending on how much the floor had sagged in the last 121 years since the rads were installed.
    • Each balanced to a tiny slope towards the valve, or at least flat, verified with digital level.
    • Where the floor had a depression rotted beneath the foot, I put the 1" OD piece first to provide support and then built on top with smaller diameter.
    • On two rads on the second floor the pieces would get loose some times. I realized that this was because the rads could lift up maybe 1/4" when the pipes got hot. As a quick sanity check calculation, with a CTE of 5.8E-6 (in Fahrenheit) for cast iron I get 5.8E-6 * 20 feet * 12 inches * (212 F- 70 F) temperature swing = 0.20" length increase from cold to hot on that riser from the basement to the second floor. The solution was to add spacers for the hot height (installed when the rad is cold!). Then the disks are always held in place by the weight of the rad, hot or cold. I'm thinking it's probably better that the 100 pound rad is not suspended above the floor, held up by the riser, but instead the riser hangs off the rad.
    In an added bonus, the one rad that would audibly drip in the wall after a heating cycle is now silent after being properly sloped.
    STEAM DOCTOREdTheHeaterMan
    EdTheHeaterMan Member Posts: 11,646
    edited May 2024
    I remember as a child of 8 or 9 years old, My father purchased a regulation pool table with a 1-1/4 slate table top.  Watching the delivery as they maneuvered down the basement steps, then assembling it piece by piece, then the final leveling of the table.   They use a very scientific and technical method to get it perfect.   The first part was to check where it was too high or too low with an 8 ft level on the long side, and then a 4 ft level on the short dimension.  But these amazing high tech leveling shims were what fascinated me the most.   I wonder if they might work for your radiators?
    It's very easy to customize the shape
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,439
    Fender washers....Mad Dog
    PC7060
  • PC7060
    PC7060 Member Posts: 1,757
