Main Venting.
Hi.
I have a quick question regarding main venting. One guy i’ve used for many years said the one is enough and sufficient, but he retired so i found a new guy. He told me that ideally there should be one that goes to every radiator but he only found the one. The main vent is located at the very end of the main, just before it turns up to the bedroom (this is the last radiator, which is also the furthest away). The main measures roughly 23 ft and 1.5 inches diameter (assuming i measured right)
