How to finance a geothermal system
What do you consider a reasonable rate?0
Call Dandelion (they advertise on Facebook a lot).
They are a national geothermal installer and they get you any incentives that you would qualify for and have financing. They are pretty expensive, but based on a quote I got from them, they know what they are doing and have the ability to do good engineering and back it up with all the documents that your local authority will need.
They will show you a 20 year cost breakdown of your current system vs ground source heating/cooling and I found it accurate (and I'm skeptical as hell).NJ Steam Homeowner.
Northern WI might be a favorable spot for this. Is a Home equity loan an option?0
Almost anywhere is favorable TBH
Cost effectiveness is the issue0
Absolutely, but with the long, maintenance-free lifetimes these things have, it's hard not to find it
I agree they can last a long time, but if you're financing it at 7%, savings in year 20 are discounted heavily (75%). And you have to stay for 20 years in the house - if you move early, no savings.0
Your best financing, assuming you have an equity stake in your house built up, is going to be a home equity loan. You might find that around 7%. Anything else is going to be more, and for a shorter term. It's just the way the markets are now.Br. Jamie, osb
Thank you very much! Unfortunately, they do not work in my area.ethicalpaul said:Call Dandelion (they advertise on Facebook a lot).
They will show you a 20 year cost breakdown of your current system vs ground source heating/cooling and I found it accurate (and I'm skeptical as hell).0 -
Thanks for the comment. Yes it is definitely an option, but I prefer not to put my house up as collateral if at all possible. We could have a good down payment and have excellent credit so I am hoping that we can find either an unsecured loan or a loan secured by the equipment itself.Hot_water_fan said:Northern WI might be a favorable spot for this. Is a Home equity loan an option?
Thank you, yeah we are trying to avoid that, but we might not have a chance.Jamie Hall said:Your best financing, assuming you have an equity stake in your house built up, is going to be a home equity loan. You might find that around 7%. Anything else is going to be more, and for a shorter term. It's just the way the markets are now.
Our plan is to not move from this house. Granted, anything could happen I suppose, but we would preferably like to stay here.Hot_water_fan said:I agree they can last a long time, but if you're financing it at 7%, savings in year 20 are discounted heavily (75%). And you have to stay for 20 years in the house - if you move early, no savings.
I did find this website: cleanenergycu.org they are a credit union that does green energy loans secured by the equipment itself, but I would be interested to see what other options are out there0
Is this system forced water or forced air?0
Look around at www.dsireusa.org
It will lead you to all the incentive programsBob "hot rod" Rohr
I know what myneighbor paid to fit his 100 yr old home with geothermal. If I tookout a 30 yr loan, I would be paying $290/mo. That is about my monthly utility bill but there are no savings. I think @Jamie Hall said it best on another tread, this should be done with all new construction. There is no excuse not to and your new house would be built tight.
Edit. Fixed math error.0 -
@SlamDunk $290/month is the issue! That’s too much when you can fit a furnace + heat pump for much less and get the same (or close enough) savings.0
WaterHot_water_fan said:Is this system forced water or forced air?
I guess that's one of my questions. If I was to just do an air to water heat pump with a back up electric boiler, how much would I actually be saving with a geothermal system? I mean, where I live in Northern Wisconsin, it gets pretty cold and stays cold for awhile, so maybe the savings from the geothermal would be worth it? Not sure.Hot_water_fan said:@SlamDunk $290/month is the issue! That’s too much when you can fit a furnace + heat pump for much less and get the same (or close enough) savings.
An hvac engineer/designer should be able to show you your current fuel costs vs the costs of a heat pump system both on day one and then over time. Try to find an independent one who is not going to make money on what your final choice is.
inputs: the amount of heating and cooling your home needs per year, upfront cost of each system, cost of fuel over time for each system, maintenance costs of each system, lifetime of each system
output: $$ over timeNJ Steam Homeowner.
I guess that's one of my questions. If I was to just do an air to water heat pump with a back up electric boiler, how much would I actually be saving with a geothermal system? I mean, where I live in Northern Wisconsin, it gets pretty cold and stays cold for awhile, so maybe the savings from the geothermal would be worth it? Not sure.Air to water is pretty uncommon, like geothermal, so the premium probably won’t be as large as air-to-air vs ground source forced air. I think still, that geothermal probably never pays for itself. Those loops are just huge costs and sometimes aren’t even more efficient than air source seasonally. You live in a cold climate, that’s a point in geothermal’s favor. Is the heat loss high? Is electricity $.25+/kWh?0
Yup thanks for that. I am working on gathering that info.ethicalpaul said:An hvac engineer/designer should be able to show you your current fuel costs vs the costs of a heat pump system both on day one and then over time. Try to find an independent one who is not going to make money on what your final choice is.
output: $$ over time0 -
Electricity is .136 kWh. I am not sure what constitutes a high heat loss, but the house is about 3800 sqft and we average about 1300 gallons of propane per calendar year over the last three years. We are no longer on propane and we are only considering electric options at this time.Hot_water_fan said:I guess that's one of my questions. If I was to just do an air to water heat pump with a back up electric boiler, how much would I actually be saving with a geothermal system? I mean, where I live in Northern Wisconsin, it gets pretty cold and stays cold for awhile, so maybe the savings from the geothermal would be worth it? Not sure.Air to water is pretty uncommon, like geothermal, so the premium probably won’t be as large as air-to-air vs ground source forced air. I think still, that geothermal probably never pays for itself. Those loops are just huge costs and sometimes aren’t even more efficient than air source seasonally. You live in a cold climate, that’s a point in geothermal’s favor. Is the heat loss high? Is electricity $.25+/kWh?0 -
@Prevch Wow! That's an efficient house, nicely done!
1300 gallons / year x 91,452 btu/ gallon * 95% efficiency (if you have a high efficiency boiler, if not use 82%)= 113 MMBtu annually going into the house. That's about 33,000kwh OUTPUT, which a heat pump with a COP of 2.5 can provide with ~13,250 kwh INPUT. That would cost $1800/year. With that annual spend, a geothermal heat pump makes little sense. Even if a geothermal heat pump could get 3.5 COP, which is not guaranteed, you'd save $500/year. That's unlikely to cover the loan payment on the additional cost of the geothermal.1 -
You'd also be missing out on the excellent cooling that a ground source heat pump provides, if I understood your situation correctly.
All this would be a waste if your house isn't well sealed and insulated.
I know my neighbor gutted his house when he bought it, sealed and insulated it.
That wasn't included in the cost for his geothermal. My gut tells me he had cash burning a hole in his pocket. His house is comfy year-round but I don't know if it would be a good fiscal decision if you had to take out a loan.
The same isn't true for other fuels that cost more per BTU??NJ Steam Homeowner.
Obviously a well sealed and insulated house is desirable. So is a vacation in Spain, or a nice Ferrari. It's not always possible, however, on a reasonable budget -- if it's possible at all. On a new build, yes, of course. On a house which is over a century old, most folks are going to want to balance the cost of sealing and insulation against the cost of energy ;-- and the answer isn't always that sealing and insulation is worth the money. The same thing applies to upgrades to the heating system or many other expenditures (we just completed an analysis of the cost/benefit of a large solar PV array, for instance. The overall cost was greater than the overall benefit over the expected life of the system, so no sale... just as an example).
The calculations aren't hard, but one needs to use reasonably accurate assumptions which can be difficult, and one must also use reasonably accurate estimates of the lost opportunity cost associated with the capital expenditure -- and that's where many people have real trouble.Br. Jamie, osb
That's good info thank youHot_water_fan said:@Prevch Wow! That's an efficient house, nicely done!
1300 gallons / year x 91,452 btu/ gallon * 95% efficiency (if you have a high efficiency boiler, if not use 82%)= 113 MMBtu annually going into the house. That's about 33,000kwh OUTPUT, which a heat pump with a COP of 2.5 can provide with ~13,250 kwh INPUT. That would cost $1800/year. With that annual spend, a geothermal heat pump makes little sense. Even if a geothermal heat pump could get 3.5 COP, which is not guaranteed, you'd save $500/year. That's unlikely to cover the loan payment on the additional cost of the geothermal.0 -
@Hot_water_fan Can you talk to me a little bit about your assumptions here in the comparison between the air source and ground source heat pump? In your scenario is the idea that the average COP for the air source heat pump for tyhe heating season will be 2.5? If so, do you think that is realistic in my climate? Same question for the 3.5 COP on the geothermal, how did you come to that figure?Hot_water_fan said:@Prevch Wow! That's an efficient house, nicely done!
Thanks so much for your insights
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
