How to finance a geothermal system
Prevch
Prevch Member Posts: 120
We are now looking at installing a geothermal system. We live in Northern, WI. The upfront cost is very high. I was just wondering if any of you have any resources related to financing geothermal at a reasonable interest rate. We have excellent credit if it matters. Any ideas?
    pecmsg Member Posts: 6,283
    What do you consider a reasonable rate?
    ethicalpaul Member Posts: 7,762
    edited October 2023
    Call Dandelion (they advertise on Facebook a lot).
    They are a national geothermal installer and they get you any incentives that you would qualify for and have financing. They are pretty expensive, but based on a quote I got from them, they know what they are doing and have the ability to do good engineering and back it up with all the documents that your local authority will need.
    They will show you a 20 year cost breakdown of your current system vs ground source heating/cooling and I found it accurate (and I'm skeptical as hell).
    dko
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,197
    Northern WI might be a favorable spot for this. Is a Home equity loan an option?
    Almost anywhere is favorable TBH :sweat_smile:
  • Hot_water_fan
    Cost effectiveness is the issue :smile:
    Absolutely, but with the long, maintenance-free lifetimes these things have, it's hard not to find it
  • Hot_water_fan
    I agree they can last a long time, but if you're financing it at 7%, savings in year 20 are discounted heavily (75%). And you have to stay for 20 years in the house - if you move early, no savings.
    Jamie Hall Member Posts: 26,169
    Your best financing, assuming you have an equity stake in your house built up, is going to be a home equity loan. You might find that around 7%. Anything else is going to be more, and for a shorter term. It's just the way the markets are now.
  • Prevch
    edited October 2023
    Thank you very much! Unfortunately, they do not work in my area.
  • Prevch
    Thanks for the comment. Yes it is definitely an option, but I prefer not to put my house up as collateral if at all possible. We could have a good down payment and have excellent credit so I am hoping that we can find either an unsecured loan or a loan secured by the equipment itself.
  • Prevch
    Thank you, yeah we are trying to avoid that, but we might not have a chance.
  • Prevch
    Our plan is to not move from this house. Granted, anything could happen I suppose, but we would preferably like to stay here.
    Hot_water_fan
  • Prevch
    I did find this website: cleanenergycu.org they are a credit union that does green energy loans secured by the equipment itself, but I would be interested to see what other options are out there
  • Hot_water_fan
    Is this system forced water or forced air?
    hot_rod Member Posts: 25,328
    Look around at www.dsireusa.org
    It will lead you to all the incentive programs
  • SlamDunk
    SlamDunk Member Posts: 1,757
    edited October 2023
    I know what myneighbor paid to fit his 100 yr old home with geothermal. If I tookout a 30 yr loan, I would be paying $290/mo. That is about my monthly utility bill but there are no savings. I think @Jamie Hall said it best on another tread, this should be done with all new construction. There is no excuse not to and your new house would be built tight.
    Edit. Fixed math error.
  • Hot_water_fan
    @SlamDunk $290/month is the issue! That’s too much when you can fit a furnace + heat pump for much less and get the same (or close enough) savings.
  • Prevch
    Water
  • Prevch
    I guess that's one of my questions. If I was to just do an air to water heat pump with a back up electric boiler, how much would I actually be saving with a geothermal system? I mean, where I live in Northern Wisconsin, it gets pretty cold and stays cold for awhile, so maybe the savings from the geothermal would be worth it? Not sure.
    Hot_water_fan
    edited October 2023
    An hvac engineer/designer should be able to show you your current fuel costs vs the costs of a heat pump system both on day one and then over time. Try to find an independent one who is not going to make money on what your final choice is.
    inputs: the amount of heating and cooling your home needs per year, upfront cost of each system, cost of fuel over time for each system, maintenance costs of each system, lifetime of each system
    output: $$ over time
  • Hot_water_fan
    edited October 2023
    Air to water is pretty uncommon, like geothermal, so the premium probably won’t be as large as air-to-air vs ground source forced air. I think still, that geothermal probably never pays for itself. Those loops are just huge costs and sometimes aren’t even more efficient than air source seasonally. You live in a cold climate, that’s a point in geothermal’s favor. Is the heat loss high? Is electricity $.25+/kWh?
  • Prevch
    Yup thanks for that. I am working on gathering that info.
  • Prevch
    Electricity is .136 kWh. I am not sure what constitutes a high heat loss, but the house is about 3800 sqft and we average about 1300 gallons of propane per calendar year over the last three years. We are no longer on propane and we are only considering electric options at this time.
  • Hot_water_fan
    @Prevch Wow! That's an efficient house, nicely done!
    1300 gallons / year x 91,452 btu/ gallon * 95% efficiency (if you have a high efficiency boiler, if not use 82%)= 113 MMBtu annually going into the house. That's about 33,000kwh OUTPUT, which a heat pump with a COP of 2.5 can provide with ~13,250 kwh INPUT. That would cost $1800/year. With that annual spend, a geothermal heat pump makes little sense. Even if a geothermal heat pump could get 3.5 COP, which is not guaranteed, you'd save $500/year. That's unlikely to cover the loan payment on the additional cost of the geothermal.
    You'd also be missing out on the excellent cooling that a ground source heat pump provides, if I understood your situation correctly.
  • SlamDunk
    All this would be a waste if your house isn't well sealed and insulated.
    I know my neighbor gutted his house when he bought it, sealed and insulated it.
    That wasn't included in the cost for his geothermal. My gut tells me he had cash burning a hole in his pocket. His house is comfy year-round but I don't know if it would be a good fiscal decision if you had to take out a loan.
  • Hot_water_fan
    Not true! You need not air seal or insulate an existing house. Especially if that house only uses 1300 propane gallons a year in Northern Wisconsin
    The same isn't true for other fuels that cost more per BTU??
    Hot_water_fan
    Obviously a well sealed and insulated house is desirable. So is a vacation in Spain, or a nice Ferrari. It's not always possible, however, on a reasonable budget -- if it's possible at all. On a new build, yes, of course. On a house which is over a century old, most folks are going to want to balance the cost of sealing and insulation against the cost of energy ;-- and the answer isn't always that sealing and insulation is worth the money. The same thing applies to upgrades to the heating system or many other expenditures (we just completed an analysis of the cost/benefit of a large solar PV array, for instance. The overall cost was greater than the overall benefit over the expected life of the system, so no sale... just as an example).
    The calculations aren't hard, but one needs to use reasonably accurate assumptions which can be difficult, and one must also use reasonably accurate estimates of the lost opportunity cost associated with the capital expenditure -- and that's where many people have real trouble.
  • Prevch
    That's good info thank you
  • Prevch
    @Hot_water_fan Can you talk to me a little bit about your assumptions here in the comparison between the air source and ground source heat pump? In your scenario is the idea that the average COP for the air source heat pump for tyhe heating season will be 2.5? If so, do you think that is realistic in my climate? Same question for the 3.5 COP on the geothermal, how did you come to that figure?
    Thanks so much for your insights
