Replacing Badly Rusted Tankless Coil on Weil Mclain EG-45 - NSFW
I've never done this before (but I'm sure it will turn out fine
On top of that, is the actual boiler sections at risk of being degraded? Should I plan on changing the whole boiler all together? Here are some NSFW pics of the damage:
So far I just cleaned off as much rust as I could around the bolt heads and sprayed Knoll. Not sure it will penetrate enough to do anything. I plan on spraying them every day for a few days. How should I try to remove them without snapping?
Any help is appreciated. Thank you.
Out of curiosity, why are you saying NSFW?Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes1 -
So you're saying the boiler could be toast because the boiler casing is rusted away? The gasket that came with the new tankless coil is a fairly thin black rubber. Could a thicker gasket be used to keep it sealed on a rusted uneven casing? Any possible solution aside from replacing the boiler?realliveplumber said:
That is if there is even the resemblance of a decent mating surface for a gasket to seal to.0 -
Are you doing this work yourself? If yes, give it a shot and see what happens. If you are hiring a professional, you need to decide if you want to invest what might be a significant amount of money. Any idea of the age of the boiler? Maybe do a boiler leak test, before investing time/money. Fill boiler to the top and see if water leaks from the sections. You will probably get leakage from the coil. Be prepared with a wet vac or towels or speedy dry or something. Would be a shame to invest time and or money into a boiler that is otherwise leaking.0
Thanks for the practical advise. I was planning on doing it myself but I'm getting worried now since I don't have any experience drilling and tapping holes and not sure what the condition of the mating surface will be underneath the coil plate. Either way I can do removals, try my best to not break the bolts, at the least the one in the picture looks like it's going to fall off by itself so I'm sure they won't come out easy. Then I'll see what I'm working with.STEAM DOCTOR said:Are you doing this work yourself? If yes, give it a shot and see what happens. If you are hiring a professional, you need to decide if you want to invest what might be a significant amount of money. Any idea of the age of the boiler? Maybe do a boiler leak test, before investing time/money. Fill boiler to the top and see if water leaks from the sections. You will probably get leakage from the coil. Be prepared with a wet vac or towels or speedy dry or something. Would be a shame to invest time and or money into a boiler that is otherwise leaking.
As far as I know the boiler was running well beside the coil leak, I was adding water every other week or so during the winter. I will fill it to the top and see. How should I check for leaks? Remove the exterior covers?
In my area (NYC) labor is not cheap so you're right that I shouldn't spend money on having someone try to mess with this when I might have to pay them to replace the whole boiler. However, a new boiler is at least $6000 from my quick search, plus the labor which will probably be at least as much. So if it's fixable that would be better but you are right that I need to make sure the rest of it is OK.
This coil looked a lot better last summer but I got caught up with other projects and didn't change it. Now it's worse.
Thanks0 -
No need to remove the cover. If the sections are shot, or if the connections are shot, you will know pretty instantly. Either water dripping on the burners, or down the side of the boiler.0
Just out of curiosity. What is that coil being used for?0
It's for baseboard radiators in the basement. Another system that I have to troubleshoot because this winter the circuit lost a lot of water and started banging on a really cold day. I had the water feed valve off since it's been always been off and I wasn't sure about it.STEAM DOCTOR said:Just out of curiosity. What is that coil being used for?
I suspected the automatic bleeder, and changed it but I don't think it bled correctly. I decided to stop using it until I changed the coil, and relied on the ductless split for heat.0 -
For your information, in the event that you need to replace the boiler, there are ways to heat basement baseboard without using a coil. Weil Mclain, is the only manufacturer who makes a gas steam boiler with a coil. And their prices are a fortune. You can probably get a less expensive boiler and work off of that. Emphasis on probably.1
That coil and boiler look pretty bad. A pro is problbly going to teel you to forget it.
But the decision is easy. "what have you got to loose?
Remove the coil and get the bolts out that you can, most of them may break,
You can drill and tap the holes and use a grinder to create a new surface for the coil.
It is chancey but you have nothing to loose except the cost of a new coil0 -
You're right. The coil is already sitting next to the boiler. I purchased it probably a year ago... Thanks
I don't even really need the baseboards. I wish I had ripped them out when I refinished the basement but I didn't have the AC back then. The AC made plenty of heat down there this winter.STEAM DOCTOR said:For your information, in the event that you need to replace the boiler, there are ways to heat basement baseboard without using a coil. Weil Mclain, is the only manufacturer who makes a gas steam boiler with a coil. And their prices are a fortune. You can probably get a less expensive boiler and work off of that. Emphasis on probably.
Now that I didn't rip them out it seems like a waste not to reconnect them..
What would you recommend as a replacement boiler? Thank you again
As you will hear many times on this site, the installer is a lot more important than the boiler. Bad installer can make any boiler bad. And vice versa. That said, for gas steam (no coil), my personal preferences are Peerless and Williamson. Williamson is a Weil McLain in disguise (just a bit cheaper and without the coil option).1
If the surface of the boiler is pitted up I would clean it up with a wire wheel and use a composition gasket instead of a resillaint gasket. A composition gasket with RTV on both sides will deal a lot better with a pitted surface. Not sure if the gasket is available from Weil or if you'd have to make one out of sheet gasket.1
Thanks so much. This kind of advise is helpful because I know my way around a wrench but have no experience with boilers.mattmia2 said:If you use a 6 point socket and a t handle and some rocking instead of just going right for it you might be surprised at how many bolts come out.
I sprayed Knoll to the bolt heads so far but I'm not sure if it's actually reaching the thread. What's the best way to make sure it's doing something?
And can you point me to the right gasket material? I have the one that came with it, black EPDM looks like but it's very thin stuff. I guess I'll have to make my own.
Is this the kind of gasket material you're thinking? I could only find 1/8" thick so far:
https://www.zoro.com/thermoseal-gasket-sheet-synthetic-fibers-c-4401/i/G4665297/?recommended=true#reviews
https://www.zoro.com/garlock-sealing-technologies-gasket-aramid-fiber-18-in-t-15-x-15-in-3000/i/G0694136/0 -
I prefer to grind the heads off the bolts, after draining the boiler & coil of course.
When you remove the coil plate the remaining studs will be protruding almost 1/2". I heat them red hot & let them cool; sometimes with the aid of a few ice cubes or snow.
I've always been able to easily remove the remaining stud with a tiny pipe wrench....
3 -
mattmia2 said:You might find that the leaking is from bolts that should have had sealant and didn't and the gasket surface is in good shape. If you can keep it off for a few days you might want to see what it looks like before you decide about using something other than the gasket that came with the new coil.0
Here is an update of the damage. I tried to heat the bolts, they turned a bit then snapped. Can it be saved? What do you guys think?
Keep going. This, as you know is very labor-intensive and a bit intimidating. Continue to heat the bolts.
You're in it now so there's no turning back. If all the bolts snap off after heating them, then go with the grind smooth and drill and tap. Dont worry. Just tough it out.
This is your plan "A". Stay with it. Hope you don't need plan "B" (replacing it.)2 -
Try some rocking back and forth before you go for it.0
I have an easy out set with reverse rotation drill bits. 9 x out of 10 the drilling heat and reverse direction does the job.0
Here is an update:
All the bolts snapped. I tried induction heating, mapp gas, smacking, back and forth by hand, impact gun, all produced the same result.Thoughts?
Thanks for reading.0 -
Seeing as ALL the bolts snapped
a) a lot of work repairing it
b) replace the boiler.0 -
Take a grinder and grind the bolts flush. Use a wire wheel and go slowly and clean the whole surface off. Keep it flat and clean it up. You don't want to be digging holes and make the surface uneven.
Then carefully center punch the bolt holes. Start with a small drill bit and work your way up. 5/16" drill is tap size drill for 3/8-16 bolts which is probably what you have.
It's going to take time . Have some patience.
At this point its your only option except for a new boiler1 -
MikeAmann said:He is not done yet. Do what @EBEBRATT-Ed said to. If you are successful, you should be able to save this boiler. The deciding factor will be how much work do you want to put into this? Do you absolutely have to have the tankless coil? You can have a laser CNC cut piece of stainless steel cut to block it off for good.1
Are you kidding? Did you look at the photos? There is no resemblance of a mating surface for a anything, let alone a gasket, to seal to.MikeAmann said:He is not done yet. Do what @EBEBRATT-Ed said to.
There is practically nothing left of the tie bolt.
That boiler has exceeded its life expectancy. It needs to be replaced. Now is the time to do it, not in January.
Its time to stop playing, replace it.2 -
What boiler would you recommend to replace this EG-45? If I wanted to keep using the baseboard what other options are there besides another boiler with a tankless coil set up? Thanks0 -
If properly sized, I would recommend a new EG-45, with tankless coil for hwbb heat.
Unless you have a lot of free time, I would suggest cutting your losses and replace the boiler. Hate to see you spend more time, only to learn you cannot get the plate to stop leaking. Worse yet, one of the sections cracks.0 -
STEAM DOCTOR said:If the baseboard is all in the basement, and the piping is all below the water line, then there is no reason in the world to use a coil.ScottSecor said:If properly sized, I would recommend a new EG-45, with tankless coil for hwbb heat. Unless you have a lot of free time, I would suggest cutting your losses and replace the boiler. Hate to see you spend more time, only to learn you cannot get the plate to stop leaking. Worse yet, one of the sections cracks.
If I ditch the baseboard in the basement do you still recommend the EG-45? Im weary of the same failure happening with the tankless coil.
Thanks everyone!
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
