TTT, teflon tape tips
The key is to start the tape one or two threads back from the end of the male thread. Not off the end like the right side of this nipple shown. Starting back a thread keeps it from getting inside and causing headaches.
Some plumbers put a coating of pipe dope over the tape. Some plumbers put pipe dope then teflon tape. Some plumbers tape the male thread and tread dope inside the fitting.
The tape should work fine by itself.
Different stokes for different folks.
I don't know there is a huge difference in tape color other than a visual. The stainless steel specific tape seems to have a coating of something like anti seize.
Is the yellow tape just a minimum thickness? Is blue monster blue tape and yellow tape the same but blue hasn't gone through an additional testing process?0
The first generation Teflon Tape I used, Dupont?? Was thick and high quality. Then all we got was thin shredding garbage tape until Blue Monster Came along. The first time I used Teflon tape in 1986, Jimmy O' Brien (Dubliner) chastised me : "Son...for @." I was on my 10th turn...ha ha 😂 🤣 .
I always use dope over the tape also. I know one VG plumber who puts Tape, wick, tape, dope on all his wet joints! Crazy, but he swears by it and they don't leak. Mad Dog 🐕0 -
Supposedly any teflon approved for gas is supposed to be a higher density material. Some white colored stuff claims to be gas approved. Im not sure who confirms that?
There is an ANSI standard for tapes., shown on this brand
Then there is the thicker tape like Mil Rose
This is both higher density, thicker and yellow colored which seem to be an industry standard color for fuel gas pipingBob "hot rod" Rohr
Living the hydronic dream1 -
I think its ridiculous, but every artist 🎨 has their touch...that's his....Not hurting any one or anything. Mad Dog 🐕0
He doesn't use a lot of tape or wick so it doesn't look as bad as you'd think. Mad Dog 🐕
I've never heard of any kind of thread sealant (approved for gas, water, etc. or not approved) not working or deteriorating over time and leaking. You'd think it would get a lot of press.
Maybe even peanut butter would work; chunky or smooth.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab2 -
Blue Monster (blue tape) in their video says that it can be use on Nat gas, however, I don't see that on their written literature of what it can be used for. Maybe the container says so? Building Inspectors expect to see yellow tape and using yellow tape saves an explanation.0
You could buy and download ANSI LC7 and see specifically what that standard and listing is about. It appears on that MilRose tape.
I suspect like most everything it will depend on the inspector of the day. Of if a locale specifically forbids it.
Here is a NC fire Marshall opinion.
https://www.ncosfm.gov/fuel-gas/40393-thread-compounds-and-ptfe-tape/openBob "hot rod" Rohr
You could also look at what spec the fuel gas code requires.0
Gas teflon (yellow) is much more dense.
Mill Rose 3 Wrap Yellow
Composition: 99.0% PTFE 1.0% Pigment
Color: Yellow
Thickness: 0.004" +/-10%
Density: 1.5g/cm3 +/-10%
Mill Rose Blue Monster
Composition 99.6% PTFE 0.4% Pigment
Color: Blue
Thickness 0.0035" +/- 10%
Density 0.8g/cm3
Less than 1.0 specific gravity will float in water
Blue monster is really just average/standard PTFE tape. But they are consistent.
White 100% ptfe tape with good density is "better."
See Merco PTFE tape M55 and M77 full density. Most guys who use this never go back to blue monster.
Blue is just a pigment, no benefit to sealing/lubricating whatsoever.
As my lawyer Bro says, "Anything not prohibited is allowed."0
I like that blue monster comes in like a 1000' roll. I don't want a 10 pack of rolls with like 6' on each roll.0
I've been using this at work a lot.
It's much thicker and.... Harder? If that makes any sense than blue monster.
But it's white.
because it is!ChrisJ said:I've been using this at work a lot.
But it's white.
3.2-3.8mil
1.2-1.55 g/cm3
white because it's 100% ptfe
spec and sticker is nearly identical to the Merco. I'm guessing the same manufacturer
When I was a lab assistant in a chemical lad , I visited the Dupont research lab in Delaware with my boss . We visited with a researh directo and he showed us a material that they just accidentially discovered while looking for something else. They named if TEFLON and thought maybe it could be use to seal threads on pipe as wel as other thngs.2
I've never noticed the pressure limitation before. So only downstream of LP first stage regsdko said:
But it's white.
3.2-3.8mil
1.2-1.55 g/cm3
I notice one has a US flag on it but does not say made in the usa.0
Gorton doesn't say made in the USA either, but this stuff appears to be unless they are lying on their data sheet:
https://tds.mercotape.com/Merco/TDS/TDS Merco Threadmaster(R) PTFE Tapes.pdfNJ Steam Homeowner.
Interesting the label limits to pipe less that 1.5”.0
I prefer Blue Monster 1/2" wide for ALL sized pipe. Pin down one end with your left thumb 👍. Pull tight, wind around tightly clockwise. 4 -5 turns Mad Dog
3 -
Someone can prove me wrong, but I have never seen a code that required the use of Yellow Teflon tape on gas.
I also find it ironic that Teflon tape has been banned for use on fuel oil for probably 40 years now where it's use on gas is not become an issue. It's the same old "gets inside the pipe issue"
For me the most important thing in any piping system is that it doesn't leak. Teflon tape with some kind of dope (no, not the installer) is pretty popular with most in the trade.
If I don't want leaks, I use Teflon unless prohibited
I've also seen guys mention that pipe dope with Teflon isn't allowed to be used with fuel oil as well. And yet, all of the chemical compatibility charts I see for PTFE list diesel as being excellent and fuel oil as being good.
There's very few things out there that aren't compatible with PTFE.
https://www.calpaclab.com/teflon-ptfe-compatibility/
Not about compatibility. Teflon works great on oil we used it all the time. But around 1980??? The way I heard it the oil pump mfg. decided that pumps returned under warranty the fittings had been turned in too tight and damaged the pumps. Also, they found Teflon in the pump strainers because people put Teflon up to the end of the nipples instead of starting 2 threads back. So they eventually got it in the codes.
Could be wrong but that is what I remember.
1
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
