TTT, teflon tape tips
hot_rod
hot_rod Member Posts: 28,065
edited August 2023 in Radiant Heating
Problems arise when the tape ends up inside the pipe as well as outside. We see "shards" in pumps, valves, strainers, etc.
The key is to start the tape one or two threads back from the end of the male thread. Not off the end like the right side of this nipple shown. Starting back a thread keeps it from getting inside and causing headaches.
Some plumbers put a coating of pipe dope over the tape. Some plumbers put pipe dope then teflon tape. Some plumbers tape the male thread and tread dope inside the fitting.
The tape should work fine by itself.
Different stokes for different folks.
I don't know there is a huge difference in tape color other than a visual. The stainless steel specific tape seems to have a coating of something like anti seize.
Mad Dog_2
    mattmia2 Member Posts: 17,859
    Is the yellow tape just a minimum thickness? Is blue monster blue tape and yellow tape the same but blue hasn't gone through an additional testing process?
    Could be the blue is a thicker tape also? Some brands advertise two wraps is all you need with the thicker versions
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,716
    The first generation Teflon Tape I used, Dupont?? Was thick and high quality.  Then all we got was thin shredding garbage tape until Blue Monster Came along. The first time I used Teflon tape in 1986, Jimmy O' Brien (Dubliner) chastised me : "Son...for @."  I was on my 10th turn...ha ha 😂 🤣 .
    I always use dope over the tape also.  I know one VG plumber who puts Tape, wick, tape, dope on all his wet joints!  Crazy, but he swears by it and they don't leak.  Mad Dog 🐕
  • ratio
    ratio Member Posts: 4,286
    How does that even work??? Wouldn't that be like ¼" thick?
    Mad Dog_2Alan (California Radiant) Forbes
    Supposedly any teflon approved for gas is supposed to be a higher density material. Some white colored stuff claims to be gas approved. Im not sure who confirms that?
    There is an ANSI standard for tapes., shown on this brand
    Then there is the thicker tape like Mil Rose
    This is both higher density, thicker and yellow colored which seem to be an industry standard color for fuel gas piping
    Mad Dog_2
  • Mad Dog_2
    I think its ridiculous, but every artist 🎨 has their touch...that's his....Not hurting any one or anything.  Mad Dog 🐕
  • ratio
    My interest is purely mechanical. The image in my mind is a big wad of stuff that gets pushed off as the threads make up, but that can't be right, right?
    Mad Dog_2LRCCBJ
    no, that's mostly what will happen
  • Mad Dog_2
    He doesn't use a lot of tape or wick so it doesn't look as bad as you'd think.  Mad Dog 🐕
    Alan (California Radiant) Forbes Member Posts: 4,836
    edited August 2023
    I've never heard of any kind of thread sealant (approved for gas, water, etc. or not approved) not working or deteriorating over time and leaking. You'd think it would get a lot of press.
    Maybe even peanut butter would work; chunky or smooth.
    hot_rodmattmia2
  • HomerJSmith
    HomerJSmith Member Posts: 2,797
    Blue Monster (blue tape) in their video says that it can be use on Nat gas, however, I don't see that on their written literature of what it can be used for. Maybe the container says so? Building Inspectors expect to see yellow tape and using yellow tape saves an explanation.
    You could buy and download ANSI LC7 and see specifically what that standard and listing is about. It appears on that MilRose tape.
    I suspect like most everything it will depend on the inspector of the day. Of if a locale specifically forbids it.
    Here is a NC fire Marshall opinion.
    https://www.ncosfm.gov/fuel-gas/40393-thread-compounds-and-ptfe-tape/open
    HomerJSmith
    You could also look at what spec the fuel gas code requires.
  • dko
    dko Member Posts: 669
    edited August 2023
    Gas teflon (yellow) is much more dense.
    Mill Rose 3 Wrap Yellow
    Composition: 99.0% PTFE 1.0% Pigment
    Color: Yellow
    Thickness: 0.004" +/-10%
    Density: 1.5g/cm3 +/-10%
    Mill Rose Blue Monster
    Composition 99.6% PTFE 0.4% Pigment
    Color: Blue
    Thickness 0.0035" +/- 10%
    Density 0.8g/cm3
    Less than 1.0 specific gravity will float in water
    Blue monster is really just average/standard PTFE tape. But they are consistent.
    White 100% ptfe tape with good density is "better."
    See Merco PTFE tape M55 and M77 full density. Most guys who use this never go back to blue monster.
    Blue is just a pigment, no benefit to sealing/lubricating whatsoever.
    GGross
  • HomerJSmith
    As my lawyer Bro says, "Anything not prohibited is allowed."
    I like that blue monster comes in like a 1000' roll. I don't want a 10 pack of rolls with like 6' on each roll.
  • ChrisJ
    ChrisJ Member Posts: 17,604
    I've been using this at work a lot.
    It's much thicker and.... Harder? If that makes any sense than blue monster.
    But it's white.
  • dko
    But it's white.
    because it is!
    3.2-3.8mil
    1.2-1.55 g/cm3
    white because it's 100% ptfe
    spec and sticker is nearly identical to the Merco. I'm guessing the same manufacturer
    ChrisJ
  • george_42
    george_42 Member Posts: 123
    When I was a lab assistant in a chemical lad , I visited the Dupont research lab in Delaware with my boss . We visited with a researh directo and he showed us a material that they just accidentially discovered while looking for something else. They named if TEFLON and thought maybe it could be use to seal threads on pipe as wel as other thngs.
    ethicalpaulrick in Alaska
    But it's white.
    because it is!
    3.2-3.8mil
    1.2-1.55 g/cm3
    I've never noticed the pressure limitation before. So only downstream of LP first stage regs :)
    I notice one has a US flag on it but does not say made in the usa.
    ethicalpaul Member Posts: 8,972
    Gorton doesn't say made in the USA either, but this stuff appears to be unless they are lying on their data sheet:
    https://tds.mercotape.com/Merco/TDS/TDS Merco Threadmaster(R) PTFE Tapes.pdf
  • PC7060
    PC7060 Member Posts: 1,881
    Interesting the label limits to pipe less that 1.5”.
  • Mad Dog_2
    I prefer Blue Monster 1/2" wide for ALL sized pipe. Pin down one end with your left thumb 👍. Pull tight, wind around tightly clockwise. 4 -5 turns Mad Dog
    ethicalpaulPC7060Alan (California Radiant) Forbes
    EBEBRATT-Ed Member Posts: 20,795
    edited August 2024
    Someone can prove me wrong, but I have never seen a code that required the use of Yellow Teflon tape on gas.
    I also find it ironic that Teflon tape has been banned for use on fuel oil for probably 40 years now where it's use on gas is not become an issue. It's the same old "gets inside the pipe issue"
    For me the most important thing in any piping system is that it doesn't leak. Teflon tape with some kind of dope (no, not the installer) is pretty popular with most in the trade.
    If I don't want leaks, I use Teflon unless prohibited
  • ChrisJ
    I've also seen guys mention that pipe dope with Teflon isn't allowed to be used with fuel oil as well. And yet, all of the chemical compatibility charts I see for PTFE list diesel as being excellent and fuel oil as being good.
    There's very few things out there that aren't compatible with PTFE.
    https://www.calpaclab.com/teflon-ptfe-compatibility/
    @ChrisJ
    Not about compatibility. Teflon works great on oil we used it all the time. But around 1980??? The way I heard it the oil pump mfg. decided that pumps returned under warranty the fittings had been turned in too tight and damaged the pumps. Also, they found Teflon in the pump strainers because people put Teflon up to the end of the nipples instead of starting 2 threads back. So they eventually got it in the codes.
    Could be wrong but that is what I remember.
