Necessity is the Mother of Invention...
I've been FORCED to do my own AC...So far, its much easier, Physically than Hot Water, Steam boilers and Plumbing. Getting guidance from a Buddy who runs a 40 Bldg megalopolis. High pressure Steam Licenses, HVAC wiz...Enjoying learning another branch of our business. Mad Dog1
Well it's far easier with ductless split units with pre flared line sets @ 15ft. Hence so many DIY kits sold online.
Will need a bunch more equipment and knowledge once you go beyond the factory supplied refrigerant limitations.
I just have a problem with Pioneer using the Taegeuk in their logo when it has no Korean affliation whatsoever.0 -
I'm being directed by a Very astute AC expert..not worried. Thanks for the Advice. Mad Dog 🐕0
Even with N2 there is the potential of copper oxide forming. Minis DO NOT have the safety of filter driers just several very fine screens. It doesn’t take much to plug one of these up but is a nightmare figuring out what one or two ARE plugged!mattmia2 said:
why not? if you actually trickle N2 or CO2 as required and heat sink it before the unit i don't see a difference between the 2.
No brazing on minis!Mad Dog_2 said:Oh yeah? Leakers? Reflare em or braze em? Mad Dog4 -
Matty...Just cover it in the Winter.. that unit is about 21 yrs old...Not ONE issue...Its Identical twin, ran for 7 yrs and then the nightmare began....Mad Dog 🐕0
Just cut the factory ends off & reflare them. (That's what the groove in the tubing cutter wheel is for! I didn't know!!) If you take a look at the factory end & a flare that you've made, you'll see what I'm talking about.
You can braze them in if you want, but that's a lot more work—unless you live in Chicago. I hear they're not allowed to use flares, or weren't. Do flow N₂, Never had a problem with clogging the screens with that.
"Frank Zappa and The Muthas...were at the best place around!" Yes, I've flared Copper tubing up to.1 1/2" . Brazing is so easy, but Flare is fine Mad Dog0
@mattmia2
I have or had a flaring tool that did 5/8", 3/4", 7/8" and 1 1/8". Never saw one larger that that except the punch type but never used one of those1 -
Yes..They are just big, Chunky Punches. I inherited an old tool box of all sizes, taps, Swedes, et cetera. We've used them on Copper Water service lines. Like all flares...dont forget to put the nut on first! Ha ha 😂 🤣 😆 😄. Nah...I NEVER forget!! Mad Dog 🐕1
Matty..what"s a "Pittsburgh" ? Is that The "Cajun lady 👩? Down around Pittsburgh...down Louisania Way ?? called the Mississippi Queen? " (Ref.Mountain) Never heard of this...Mad Dog 🐕0
I was thinking you needed the machine to do it on a curve, you can do it albeit rather tediously on a straight section with a brake. Now that i think about it more, i bet the curved pittsburgh is done on a flat piece that is rolled in to a curve after and the 90 that locks in to it is made around the curve with something like a hand seamer. i don't know if it is a regional thing, but this is how most ductwork is made around here.
There is a machine that can form that on the edge of a piece of sheetmetal with a series of rollers sort of like a continuous gutter machine.1 -
Mini's don't generate enough static pressure to require the use of a trap. Better not to use one.Mad Dog_2 said:Can reuse my Homemade Condensate trap...Mad Dog 🐕1 -
Most expensive condensate trap ever.Mad Dog_2 said:Can reuse my Homemade Condensate trap...Mad Dog 🐕
2 -
Yup! I know...thanks Harvey.. That's for the 2nd floor Ducted unit that will be going in next. Mini split is JUST for the 3rd Floor. I look at it this way: 21 years later, I'd probably be replacing it if it were PVC.. Mad Dog 🐕1
but only because it is cheap and a pain to glue old pvc in to new, not because it was in poor condition.Mad Dog_2 said:Yup! I know...thanks Harvey.. That's for the 2nd floor Ducted unit that will be going in next. Mini split is JUST for the 3rd Floor. I look at it this way: 21 years later, I'd probably be replacing it if it were PVC.. Mad Dog 🐕
Who is "Pioneer" ?
I've never heard of that brand of mini split?
A pad would be advisable, no? A level too, and bolts for those feet, right guys? Like how you advised that recent homeowner?
I just stuck it on the old pad until I get the main condenser and see if I'll need a Third concrete pad. Mad Dog0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
