Necessity is the Mother of Invention...
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,570
    I've been FORCED to do my own AC...So far, its much easier, Physically than Hot Water, Steam boilers and Plumbing.  Getting guidance from a Buddy who runs a 40 Bldg megalopolis.  High pressure Steam Licenses, HVAC wiz...Enjoying learning another branch of our business.  Mad Dog
    PC7060
  • dko
    dko Member Posts: 669
    edited July 2023
    Well it's far easier with ductless split units with pre flared line sets @ 15ft. Hence so many DIY kits sold online.
    Will need a bunch more equipment and knowledge once you go beyond the factory supplied refrigerant limitations.
    I just have a problem with Pioneer using the Taegeuk in their logo when it has no Korean affliation whatsoever.
    pecmsg Member Posts: 7,119
    Cut out and replace the factory flares on that line set!
    ratiomattmia2GGross
  • ratio
    ratio Member Posts: 4,248
    The factory flares are only there to hold the nut on during shipping—& they fail at that from time to time. Since you're supposed to discard them & use the nuts from the unit anyway, I dunno why they even put them on.
    Mad Dog_2
  • Mad Dog_2
    Oh yeah?  Leakers?  Reflare em or braze em?  Mad Dog
  • Mad Dog_2
    I'm being directed by a Very astute AC expert..not worried.  Thanks for the Advice.   Mad Dog 🐕
    No brazing on minis!
    Mad Dog_2GGross
    mattmia2 Member Posts: 16,949
    why not? if you actually trickle N2 or CO2 as required and heat sink it before the unit i don't see a difference between the 2.
    Mad Dog_2
    When you asked about this i was going to say you should make friends with a machine that can roll a pittsburgh but looks like you won't need that.
    Mad Dog_2
    How did you keep the powder coat on the grill on that lennox from peeling and rusting?
    Mad Dog_2
    Even with N2 there is the potential of copper oxide forming. Minis DO NOT have the safety of filter driers just several very fine screens. It doesn’t take much to plug one of these up but is a nightmare figuring out what one or two ARE plugged!
    mattmia2dkoSTEVEusaPAMad Dog_2
    I'd be super concerned about people reaming the copper if that were the case.
    Mad Dog_2
  • Mad Dog_2
    Matty...Just cover it in the Winter.. that unit is about 21 yrs old...Not ONE issue...Its Identical twin, ran for 7 yrs and then the nightmare began....Mad Dog 🐕
    EdTheHeaterMan Member Posts: 12,337
    Who's the Father?
    Solid_Fuel_ManMad Dog_2
  • ratio
    Just cut the factory ends off & reflare them. (That's what the groove in the tubing cutter wheel is for! I didn't know!!) If you take a look at the factory end & a flare that you've made, you'll see what I'm talking about.
    You can braze them in if you want, but that's a lot more work—unless you live in Chicago. I hear they're not allowed to use flares, or weren't. Do flow N₂, Never had a problem with clogging the screens with that.
    Mad Dog_2
  • Mad Dog_2
    "Frank Zappa and The Muthas...were at the best place around!" Yes, I've flared Copper tubing up to.1 1/2" .  Brazing is so easy, but Flare is fine    Mad Dog
    When i've seen it done on over 1" it was done with some sort of a punch and a hammer.
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 20,277
    @mattmia2
    I have or had a flaring tool that did 5/8", 3/4", 7/8" and 1 1/8". Never saw one larger that that except the punch type but never used one of those
    Mad Dog_2
  • Mad Dog_2
    Yes..They are just big, Chunky Punches.  I inherited an old tool box of all sizes, taps, Swedes, et cetera. We've used them on Copper Water service lines. Like all flares...dont forget to put the nut on first!   Ha ha 😂 🤣 😆 😄.   Nah...I NEVER forget!!  Mad Dog 🐕
    PC7060
  • Mad Dog_2
    Matty..what"s a "Pittsburgh" ?  Is that The "Cajun lady 👩? Down around Pittsburgh...down Louisania Way ?? called the Mississippi Queen? " (Ref.Mountain) Never heard of this...Mad Dog 🐕
    edited July 2023
    I was thinking you needed the machine to do it on a curve, you can do it albeit rather tediously on a straight section with a brake. Now that i think about it more, i bet the curved pittsburgh is done on a flat piece that is rolled in to a curve after and the 90 that locks in to it is made around the curve with something like a hand seamer. i don't know if it is a regional thing, but this is how most ductwork is made around here.
    There is a machine that can form that on the edge of a piece of sheetmetal with a series of rollers sort of like a continuous gutter machine.
    Mad Dog_2
  • Mad Dog_2
    Ahhh..Mad Dog 🐕
  • Mad Dog_2
    Can reuse my Homemade Condensate trap...Mad Dog 🐕
  • Harvey Ramer
    Harvey Ramer Member Posts: 2,289
    Mini's don't generate enough static pressure to require the use of a trap. Better not to use one.
    Mad Dog_2
  • realliveplumber
    realliveplumber Member Posts: 354
    Most expensive condensate trap ever.
    Mad Dog_2mattmia2
  • Mad Dog_2
    Yup!  I know...thanks Harvey..  That's for the 2nd floor Ducted unit that will be going in next.  Mini split is JUST for the 3rd Floor. I look at it this way:   21 years later, I'd probably be replacing it if it were PVC.. Mad Dog 🐕
    Harvey Ramer
    but only because it is cheap and a pain to glue old pvc in to new, not because it was in poor condition.
  • ChrisJ
    ChrisJ Member Posts: 17,442
    Who is "Pioneer" ?
    I've never heard of that brand of mini split?
  • dko
    edited July 2023
    ChrisJ said:
    Who is "Pioneer" ?
    Just another Midea resticker
    imported by Parker Davis HVAC International
    same as Cooper and Hunter (Comfortside LLC)
    and Bosch Climate 5000
    and the list goes on
    ChrisJ
    ethicalpaul Member Posts: 8,884
    A pad would be advisable, no? A level too, and bolts for those feet, right guys? Like how you advised that recent homeowner?
  • Mad Dog_2
    I just stuck it on the old pad until I get the main condenser and see if I'll need a Third concrete pad.  Mad Dog
