R422B vs R22
I know R422B calls for complete extraction of R22 before conversion.
Why is this? What happens when an R22 system is topped off with R422B? Do the chemicals mix and cause a reaction? Does it stop working?
    pecmsg Member Posts: 6,266
    It’s illegal to knowingly mix refrigerants except is certain applications.
    Once mixed it’s a guess for readings!
    Jamie Hall Member Posts: 26,146
    Or another way of putting it is that the two compounds have very different pressure/evaporating point curves, and if you mix them you have no clue as to how -- or if == the system will operate.
    and it happens more than you know!
  • rsilvers
    rsilvers Member Posts: 182
    Yes I saw a post from someone who had a contractor that topped off his R22 system with R422B but put R22 on the invoice.
  • rsilvers
    Is that true? I looked up charts for both and they were virtually identical.
    https://forane.arkema.com/files/live/sites/shared_arkema/files/downloads/fluorochemicals/forane-22-pressure-temperature-chart.pdf
    https://www.uri.com/INTERSHOP/static/WFS/URI-URIUS-Site/-/URI-URIUS-smb-responsive/en_US/docs/Nat-R422B-SS.pdf
    rsilvers said:
    Is that true? I looked up charts for both and they were virtually identical. https://forane.arkema.com/files/live/sites/shared_arkema/files/downloads/fluorochemicals/forane-22-pressure-temperature-chart.pdf https://www.uri.com/INTERSHOP/static/WFS/URI-URIUS-Site/-/URI-URIUS-smb-responsive/en_US/docs/Nat-R422B-SS.pdf
    You’re still mixing refrigerants.
    Against the law!
    Close only counts in horseshoes and grenades. But the fact that they are very similar does mean that you won't have to change out the compressor or perhaps even the control valve or orifice to make the switch.
  • rsilvers
    I am only adding R22. I was trying to find out if there is a technical reason why they can't be mixed or if that is just regulation. Seems like regulation.
    And the fact that when recovered it has to be burned?
  • rsilvers
    edited July 2023
    Burning is good because it takes R22 out of circulation where it can leak, although if the tank gets rejected then you won't get paid for it.
    pecmsg
  • ratio
    ratio Member Posts: 4,049
    Isn't it the chlorine in 22 that's eating the ozone? What happens to it when it goes through the flame? It obviously isn't destroyed, is it compounded into something that doesn't break down? Or do they capture it?
  • ChrisJ
    ChrisJ Member Posts: 16,819
    @rsilvers
    No one on here is actually going to know what happens if you mix them unfortunately.
    They only know what the law is.
    You see some speculation, but no one is going to have the real answer.
    It isn't so much the chlorine as the way it is combined with carbon and fluorine. The resulting molecules act as a catalyst which facilitates the breakdown of ozone, but isn't itself consumed in the process. If you were to burn it at a high enough temperature (I forget the value, but it's very high) the refrigerant breaks down into various chlorine, fluorine, and carbon oxides which don't do that (at intermediate temperatures, some of those are even worse -- not so much for ozone, but for living things...)
    HVACNUT
  • rsilvers
    edited July 2023
    The EPA loves burning R-22. They love it so much, they pay good money to buy R-22 just to burn it. Also, this money is part of their budget, so they love showing Congress how much R-22 they burn. The more the better. They certainly prefer to burn it than to see people reuse it.
    where did you come up with this?
  • ChrisJ
    It's the first I'm hearing of it.
    HVACNUT Member Posts: 6,835
    edited July 2023
    You got any reliable links to back up that statement? Because that's a doozy.
    edited July 2023
    X-2
  • ChrisJ
    Yeah well.
    I hear @Jamie Hall loves burning R290.   He burns tons of it and even cooks animals with it.
    JUGHNEratioGGross
    I still use NG
  • ChrisJ
    pecmsg said:
    I still use NG
    Oh so you're over there burning R50!
    They’ll get my 1940 chambers stove right after they get my gun(s).
  • ChrisJ
    edited July 2023
  • rsilvers
    I wouldn't ask this question today. Since I made this post, I studied for and became Type-1 certified. So now I know why one can't do this.
    PC7060
