R422B vs R22
Why is this? What happens when an R22 system is topped off with R422B? Do the chemicals mix and cause a reaction? Does it stop working?
It’s illegal to knowingly mix refrigerants except is certain applications.Once mixed it’s a guess for readings!0
Or another way of putting it is that the two compounds have very different pressure/evaporating point curves, and if you mix them you have no clue as to how -- or if == the system will operate.Br. Jamie, osb
and it happens more than you know!0
Is that true? I looked up charts for both and they were virtually identical.Jamie Hall said:Or another way of putting it is that the two compounds have very different pressure/evaporating point curves, and if you mix them you have no clue as to how -- or if == the system will operate.
https://forane.arkema.com/files/live/sites/shared_arkema/files/downloads/fluorochemicals/forane-22-pressure-temperature-chart.pdf
https://www.uri.com/INTERSHOP/static/WFS/URI-URIUS-Site/-/URI-URIUS-smb-responsive/en_US/docs/Nat-R422B-SS.pdf
Is that true? I looked up charts for both and they were virtually identical. https://forane.arkema.com/files/live/sites/shared_arkema/files/downloads/fluorochemicals/forane-22-pressure-temperature-chart.pdf https://www.uri.com/INTERSHOP/static/WFS/URI-URIUS-Site/-/URI-URIUS-smb-responsive/en_US/docs/Nat-R422B-SS.pdfAgainst the law!0 -
Close only counts in horseshoes and grenades. But the fact that they are very similar does mean that you won't have to change out the compressor or perhaps even the control valve or orifice to make the switch.Br. Jamie, osb
I am only adding R22. I was trying to find out if there is a technical reason why they can't be mixed or if that is just regulation. Seems like regulation.0
Isn't it the chlorine in 22 that's eating the ozone? What happens to it when it goes through the flame? It obviously isn't destroyed, is it compounded into something that doesn't break down? Or do they capture it?0
@rsilvers
No one on here is actually going to know what happens if you mix them unfortunately.
They only know what the law is.
You see some speculation, but no one is going to have the real answer.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
It isn't so much the chlorine as the way it is combined with carbon and fluorine. The resulting molecules act as a catalyst which facilitates the breakdown of ozone, but isn't itself consumed in the process. If you were to burn it at a high enough temperature (I forget the value, but it's very high) the refrigerant breaks down into various chlorine, fluorine, and carbon oxides which don't do that (at intermediate temperatures, some of those are even worse -- not so much for ozone, but for living things...)ratio said:Isn't it the chlorine in 22 that's eating the ozone? What happens to it when it goes through the flame? It obviously isn't destroyed, is it compounded into something that doesn't break down? Or do they capture it?
The EPA loves burning R-22. They love it so much, they pay good money to buy R-22 just to burn it. Also, this money is part of their budget, so they love showing Congress how much R-22 they burn. The more the better. They certainly prefer to burn it than to see people reuse it.0
where did you come up with this?rsilvers said:The EPA loves burning R-22. They love it so much, they pay good money to buy R-22 just to burn it. Also, this money is part of their budget, so they love showing Congress how much R-22 they burn. The more the better. They certainly prefer to burn it than to see people reuse it.
HVACNUT said:rsilvers said:The EPA loves burning R-22. They love it so much, they pay good money to buy R-22 just to burn it. Also, this money is part of their budget, so they love showing Congress how much R-22 they burn. The more the better. They certainly prefer to burn it than to see people reuse it.0
Yeah well.
I hear @Jamie Hall loves burning R290. He burns tons of it and even cooks animals with it.
3 -
I still use NG0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
