Interesting (Webster) System Problems Today.
Lately, the system has been spewing lots of steam and condensate out of the air vents accompanied by a great deal of noises that are new to the residents.
This one's going to be interesting and I'm looking forward to getting it straightened out as best I can considering I may be limited to how low I can get the pressure and the fact that all the condensate is dumped into the sewer at every cycle.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
@Gordo has a lot of experience with these- Baltimore has district steam too.All Steamed Up, Inc.
Consulting2 -
I love 💘 it...you'll figure it out, John. Looks like asbestos...that always complicates things ..Keep us apprised . Mad Dog
Cutting my teeth in thr World Famous Rockefeller Center in the mid 80s, it always bothered me, as a Water Conservationist , the copius amount of waste steam and condensate that occurred. Can't we do SOMETHING with all the condensate besides waste it in to the NYC sanitary system AND overload the Sewage treatment plants?? The newer codes have addressed this and some buildings are up to speed and re-purposing the waste water. Eager to see what you find Johnny NY. Mad Dog0
I LOVE that original mixing valve thingee on that tank. If you cut it out, I will personally take it out to the Heating museum at Suffolk CC. Mad 🐕 Dog1
Matt, a lot of people, including we at the General Society of Mechanics and Tradesmen run the hot condensate through a pre-heater heat exchanger donated by Taco before the cold water gets to our electric water heater, which now never turns on. We recover enough heat from our condensate that we never need to make domestic hot water with any other source (in the heating months).Mad Dog_2 said:Cutting my teeth in thr World Famous Rockefeller Center in the mid 80s, it always bothered me, as a Water Conservationist , the copius amount of waste steam and condensate that occurred. Can't we do SOMETHING with all the condensate besides waste it in to the NYC sanitary system AND overload the Sewage treatment plants?? The newer codes have addressed this and some buildings are up to speed and re-purposing the waste water. Eager to see what you find Johnny NY. Mad Dog
Classes8 -
That's what I like to hear, Johnny. I still haven't gotten to see that basement steam handiwork you, Alex the Wire Nut and Dan did at The General Society....I hope we have time to finally see it the next we're both at a Lecture. It would be cool. Mad Dog0
Works better than pressure reducing station. Control is similar but condensate from high pressure supply is handled easier. Plus one never knows what is in steam supply.mattmia2 said:I wonder if one could solve the problems of corrosion and pressure with a steam to steam hx and keeping the house system a mostly closed system and using the higher pressure district steam to make steam in the house system through a hx.
We use high pressure steam through large heat exchangers to energize circulating hot water systems and DHW frequently. The high pressure stuff is dangerous and I'm happy to convert it to something easier to deal with as quickly as possible.
Classes3 -
Heat exchangers also can generate lower pressure steam. Some industrial facilities use pressure reducing stations instead. How condensate is handled gets complicated when they're staged to successively reduce pressure. When steam was big business people experimented with different designs for those steam to steam heat exchangers.
European district heating distributes high temperature water so I imagine somebody has hot water to steam generators?
A HX would let you keep the same water in the system so you're adding a lot less oxygen to the iron in the system.
@Mad Dog_2 Love to catch up with you and give you tour of the basement with John. Lots of things going on at the GSMT and it gets better and more beautiful as time goes on.
They are currently rebuilding the library skylight but they are still running lectures. Let us know when you think you'll be there!
Alex, the Wire Nut!
"Let me control you"
Lost in SOHO NYC and Balmy Whites Valley PA2 -
I thought you'd neva ask Dahling!! Ha ha. Sounds good. Ill bring the popcorn & Bon Bons....I hope to be at Next Lecture.Mad Dog
2-Pipe Steam Bonus Feature: Heating from both ends of the radiators.
Classes3 -
Looks like steam getting into the returns somewhere, along with bad traps.All Steamed Up, Inc.
Consulting3 -
- 50 Industry Classes
