A (true) narrative about heat pumps, backup heat sources, and considerations when going all electric
I am a part time farmer and tinkerer on all things including HVAC systems, but for my day job I have a vice president level position in the electric power generation industry. My team touches double digit percentages of the installed capacity in multiple global portfolios where we provide control systems integration and operations support to these clients. I have stayed hands on and maintained my certification in multiple markets as a bulk power generation resource operator occasionally personally help out with technical problems when they're interesting or critical, which is part of why I was so aware of what happened as it happened.
I wrote the attached piece after we narrowly averted a problematic situation in the eastern US right before Christmas. It's rather long and technical but is 100% nonfiction and very important for people considering retrofitting heat pumps to understand. Enjoy!
That was a fascinating read. That event was the first time I've ever experienced ConEd sending out a message asking customers to reduce gas usage as much as possible (we have a gas boiler), or they might not be able to maintain pressure. My boiler used 2.78 therms on the 23rd, 7.12 therms on the 24th (setting my highest recorded efficiency of 69% with 53 HDD averaged for the 24hour period) and back down to 4.68 therms on the 25th. I rewired my boiler this fall to be able to operate from a battery or generator if the power goes out, but i'm out of luck if the gas network fails.1
Great write up! I’m pragmatic - if the grid needs fossil backup instead of resistance I’m all for it - they just need to tell me. 99% of the time, I’ll be using electricity.0
@Hot_water_fan here I am, telling you. This is part of why I introduced my role at the start of the thread; no large utility company in the US is going to come out and say we're totally and utterly boned unless we dramatically change course immediately, but that is in fact the case and more people need to realize it.Hot_water_fan said:Great write up! I’m pragmatic - if the grid needs fossil backup instead of resistance I’m all for it - they just need to tell me. 99% of the time, I’ll be using electricity.
The closest public plea for sanity I can point you to is PJM's recent publication regarding resource adequacy: https://insidelines.pjm.com/pjm-details-resource-retirements-replacements-and-risks/
ISO New England put one out in 2018 that was similar, but no one seems to have done anything about it.1 -
PS - Here's the ISO-NE one from 2018: https://www.iso-ne.com/static-assets/documents/2018/01/20180117_operational_fuel-security_analysis.pdf
Of particular interest is figure 5, which shows how one potential scenario could lead to six (6) days of involuntary load shedding in February:
@- . "They" (yes you!) want to paint us as Neanderthals who want polluted drinking water & air.. Brownfields, pave over the forests..We want to chew on pig lead like candy, breathe Asbestos-laden air, Oversize our boilers, shun green technologies like Solar PV and Thermal. Whom do you think PAYS for all the Conservation programs?? ...We outdoorsman with our licensing fees.. We care JUST AS MUCH AS YOU DO...ITS NOT YOUR MONOPOLY..WE ARE ON BOARD TOO! But we are logistical, not hysterical, and pragmatic. The Holy Roman Empire was not built in a day....We're on this...we got this 👍. Work with us instead of ad hominim jibes and pokes.. We are all Concerned Americans.. The debate floor is open and it can't be ONE-SIDED...JUST HERE TO HELP....Mad Dog0
@vtfarmer thanks, I just read it. We’ve added capacity in the past and there are cooling dominated southern states with extremely high peaks. What’s the difference here? It seems like some places have figured it out and we’ll have decades to figure out the heat pump part of the equation. I’m not saying it’s not challenging or that if happened tomorrow it wouldn’t be a problem - but it won’t happen tomorrow. At the end of the day, a utility should like selling electricity yes?1
@- . "They" (yes you!) want to paint us as Neanderthals who want polluted drinking water & air.. Brownfields, pave over the forests..We want to chew on pig lead like candy, breathe Asbestos-laden air, Oversize our boilers, shun green technologies like Solar PV and Thermal. Whom do you think PAYS for all the Conservation programs?? ...We outdoorsman with our licensing fees.. We care JUST AS MUCH AS YOU DO...ITS NOT YOUR MONOPOLY..WE ARE ON BOARD TOO! But we are logistical, not hysterical, and pragmatic. The Holy Roman Empire was not built in a day....We're on this...we got this 👍. Work with us instead of ad hominim jibes and pokes.. We are all Concerned Americans.. The debate floor is open and it can't be ONE-SIDED...JUST HERE TO HELP....Mad Dog? Was this supposed to be addressed to me? If so, I think the easiest path is heat pump when AC breaks, keep the furnace/boiler. How’s that for pragmatic?
As for the rest, I’m not sure what to say.1 -
Thanks for that, I read it. But what’s the takeaway?
my takeaway is: heat pumps will continue to be improved to work in low temps (I prefer ground source myself) and the grid will continue to be improved.
Did anything actually fail in your story?NJ Steam Homeowner.
What does your brother do at the power plant?EBEBRATT-Ed said:My brother works at a power plant and has one short statement. "The grid can't handle it"Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
The takeaway is that we very narrowly avoided rolling blackouts from Maine to Virginia, and actually had them from North Carolina south and west. There is NOT new generating capacity being built more quickly than it's being retired and the projections are that capacity will likely NOT be adequate to meet demand in the next few years if nothing changes.ethicalpaul said:Thanks for that, I read it. But what’s the takeaway?
Use a heat pump if you like (I do), but be prepared to not be able to use it (and likely not have power at all) when the weather gets really cold.
That's my takeaway.2 -
So you're saying they cannot build more generating capacity fast enough or just choose not to?vtfarmer said:Thanks for that, I read it. But what’s the takeaway?
The takeaway is that we very narrowly avoided rolling blackouts from Maine to Virginia, and actually had them from North Carolina south and west. There is NOT new generating capacity being built more quickly than it's being retired and the projections are that capacity will likely NOT be adequate to meet demand in the next few years if nothing changes. Use a heat pump if you like (I do), but be prepared to not be able to use it (and likely not have power at all) when the weather gets really cold. That's my takeaway.
Did anything actually fail in your story?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
So you're saying they cannot build more generating capacity fast enough or just choose not to?ChrisJ said:vtfarmer said:
That's my takeaway.
Yes. See the PJM article I linked:
@hot_rod - I think a lot of those facilities are actually tolerant of demand-side management (i.e. being asked to turn off when demand surges), particularly if it gets them cheaper rates. Data centers frequently have backup generators when their operation is critical. I know my organization temporarily powered down much of our compute resources in manhattan the 2 or 3 times things got dicey last summer during heat waves.
I think economics will probably continue to drive us towards increasing amounts of solar/wind for the bulk of produced GWh (with economic incentives increasingly shifting demand to follow supply), with batteries for short-term load shifting and hydro, gas or oil plants filling in the rest. Nobody is will to pay for new nuclear plants or coal plants, and existing coal plants are increasingly uneconomic to operate. I've seen some neat presentations on geographically distributed data centers that can move loads around in real-time to wherever power costs are cheapest.0 -
@vtfarmer I was hoping you would mention your favorite part of energy grid trivia! I'm deeply involved with that small part of Northern Maine which is not connected to any part of the US.
That night we saw 60MPH winds, and a rather typical 10F temps. Lots of homes were out of power for days, due to down lines.
2 big takeaways:
1. You MUST have a backup plan, either a large enough generator with enough fuel on site to carry you though
2. A wood stove, or non-electric propane heater. Wood stove is preferable here in the country.
When the power goes out, a small Honda generator and a couple of 5gal cans of gas will run your oil/LP boiler/furnace/pellet stove/fridge and lastly a wood stove with a couple of pickup loads of wood. You will make ot through 99% of anything.
Being completly reliant on the grid when it's frigid and then the lights go out due to an unforseen problem which is both out of your control and unpredictable in nature is just blind.
Heat pumps are great, but they must be considered a secondary source of heat, that old furnace, or stove must be thought of as primary.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!3 -
Hot water fan: Are you familiar with the great, song Paranoia (Big Destroyer) by the Kinks? Ha Ha...Actually, I wasn't even thinking about anyone in particular, just the Utopians that get hysterical and personal over the Force-fed rush to electrify-NOW! Mad Dog0
@ChrisJ
Control room operator sometimes. Also supervises some maintenance. They are a gas or oil-fired plant and are paid to be on standby most of the time and come online if another plant has problems. Tied into ISO New England0 -
