Ok to route radiant PEX under joist instead of through?
I'm installing PEX in joist bays above a crawlspace.
I'm struggling to feed the PEX back and forth between joist bays because it's binding in the 2" holes I drilled, so I wonder if I can instead just cross under the joists to get between the bays, and maybe put a bit of pipe insulation over the small section of PEX that would pop out below the joist.
I'll be curious to see what the pros say, but I can't see why not...but how is 1/2" (presumably) Pex binding in a 2" hole?
Also, is the crawlspace conditioned? Or open to the freezing outdoors?NJ Steam Homeowner.
It really starts binding after it's gone through 2+ bays. I guess the little bit of drag from each hole adds up. And I tried pulling the whole pipe length through each bay, but it gets really twisty. So going under the joist seems a lot easier. I guess just held in place with a pex talon or something and covered in some foam rubber pipe insulation?ethicalpaul said:I'll be curious to see what the pros say, but I can't see why not...but how is 1/2" (presumably) Pex binding in a 2" hole?
The crawlspace isn't conditioned. I'll be insulating the bays.0 -
Ahh well you can't just pull it through multiple bays, you have to push it through one bay at a time, with the correct single "twist" in it so that it ends up in the right pattern.
It will be a lot easier to insulate it well if it's all in the bays and not coming underneath each one.NJ Steam Homeowner.
See my pics here. I'm a DIYer too. In a crawlspace is not nearly as fun I'm sure:
https://forum.heatinghelp.com/discussion/183827/recommended-floor-condition-for-radiant-over-heart-pine-plankNJ Steam Homeowner.
for insulating purposes, it will be a lot easier if your pipe isnt running below the joist to get to the next bay.0
Yeah that appears to be the tradeoff for me right now. Easier to install the pex vs easier to insulate the pex.yellowdog said:for insulating purposes, it will be a lot easier if your pipe isnt running below the joist to get to the next bay.
YesJamie Hall said:I hope those holes were less than a third of the depth of the joist, and located on the midline of the joist... otherwise you have created a serious structural issue there.
How do you do the correct single twist?ethicalpaul said:Ahh well you can't just pull it through multiple bays, you have to push it through one bay at a time, with the correct single "twist" in it so that it ends up in the right pattern.
I was wondering if it was possible to keep the pipe somehow organized or coiled back up at the end of each bay as you pull through.0 -
You really need two people on those radiant staple up crawl space jobs. One to feed the pex and keep turning to stop kinks and one to fasten to the plates. Technically you're cheating by crossing under the joists but you gotta do what you gotta do. It's not the end of the world. Mad Dog 🐕1
Thanks. If I'm technically cheating does that mean it wouldn't pass inspection?Mad Dog_2 said:You really need two people on those radiant staple up crawl space jobs. One to feed the pex and keep turning to stop kinks and one to fasten to the plates. Technically you're cheating by crossing under the joists but you gotta do what you gotta do. It's not the end of the world. Mad Dog 🐕
@watercourse LOL most inspectors won't go in a crawl space or on a roof .......at least around here.1
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
