They asked to take a look, so I did.
Double D
Member Posts: 465
Now I want to forget I was there. They said the boiler is only a year old. Ouch!!
That's some workmanship there!0
WOW!! Are you sure that this is for real and not just a nightmare. You might have luck on your side since steam boilers are usually only warranted for 1 year. If the customer has deep pockets you could have a crew there for a long time. This would be great if you need the work.0
I don't have the time to take it on but I did recommend a contractor who he can call. If I were to take it on, he would need to address the leaks in the system or I wouldn't touch it. He didn't want to hear anything about the leaks, he just wanted to fix what was stopping it from heating.There isn't a lot of steam knowledge in my area. He may be able to get someone to replace the 3 affected sections and burners. I sure hope he has the deep pockets you mention. He wanted me to put sealer in and start it up. I told him he can put sealer in, I'm not a fan of it.0
What is this?
You mean the fitting or the piping configuration?0
- 117 Geothermal
