AC Line set leak at air handler
Is it oily or is it just a condensate leak from the coil?0
Who knows how many hands could have man handled that line in 11 years?0
I do, the guy that installed it.0
How long do you feel it should be covered under warranty?Jon_blaney said:I do, the guy that installed it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
11 years without a problem , I would recommend checking the coil ..
Who to hold responsible? What a novel concept! Perhaps the person that placed that coil inside that particular cabinet on that given day at manufacturing plant. Is there any labels or stickers from quality control affixed to the appliance? Maybe Inspector #9 was at fault. Did the manufacturer offer a warranty on that appliance. The document should be in your paperwork. Look it up. I'm sure there is a mention of defects in material and workmanship. It probably has a number of years listed on it. If you are lucky, it is 12 years!
And if inspector # 9 won't stand by his 11 year old work, then perhaps an attorney can find someone who can be held accountable for this travesty of justice. Of course , be sure that the lawyer takes the case on contingency. This will be incentive to get results. Why should you pay for a lawyer if he can't get results anyway.
And you should also get a trophy attending any sporting event even if you loose. Because that is the way the world works. Everybody gets a trophy and everything is fair and no one gets the short end of the deal. Fair is fair!
As I said earlier. Good Luck With That!Edward Young Retired
2 -
So, no one's touched it in 11 years?Jon_blaney said:I do, the guy that installed it.
How long do you feel it should be covered under warranty?ChrisJ said:Jon_blaney said:I do, the guy that installed it.
11 1/2 years!
2 -
"If this is the case, does the installer bear some or all the responsibility for the problem? The install was about 11 years ago." @Jon_blaney
"I do, the guy that installed it." @Jon_blaney
Are you asking if this chafe was your own fault?0 -
Perhaps there is a lifetime warranty on that system, Unfortunately the guy who offered the lifetime warranty died last year, maybe we can look up who the executor of the estate is. I'm sure confident there will be money set aside in an escrow account with @Jon_blaney's name on it. It will also have a cost of living increase allowance and interest earning contingency, Jon is in for a win fall! If I could be so lucky
We never really answered the question about if this spot is oily. If it isn't oil, it is just condensate that isn't going where it is supposed to.HVACNUT said:You suspect a lot of things. But do you actually know anything? No, no you don't.
Could be a bad capacitor for all you know. Has it gotten annual maintenance over the 11 years, other than replacing the air filter?
Have it checked. Get the facts ma'am, just the facts.0 -
You are missing the BIG PICTURE here. We need to form a class action that will cover all refrigerant leaks since the inception of Apparatus For Controlling Humidity" over 100 years ago. Willis Carrier's Heirs can afford it!mattmia2 said:
I will be contacting the firm of Dewey, Cheatham and Howe. They are specialist in this type of litigation.
Who else is on board? Sign the petition here X________________________
.......... OR .........
Press the Litigate On Leaks (LOL) below and no one will contact you to add you to the List On Leaking refrigerant.
2 -
C'mon, this is getting a little silly. The OP asked a simple question. Maybe a little offensive to those of us in the field, but not completely unreasonable. Judging by his post count, he's not a one-post wonder looking to dun his installer (although he may not be back after reading some of this stuff, I wouldn't).2
Dig out your paperwork from 11 years ago and see what the labor warranty is.Prolly not even the issue! If your air handler vibrates that much, you have lots of issues
no “chaffed” leak will blow out all at once.
id love to be a fly in the wall when you confront the technician0
- 123 Chimneys & Flues
