Steam Boiler Sizing, Small Home
Find out what residential code your city/township/county uses and look in the mechanical section. Look in the general or administration section at the beginning and look go see if there is a boilers section and look in there. You may have to go to a library, some codes are only available if you purchase them.
Here are some examples from the 2015 michigan residential code:
The codes pretty much confine themselves to safety, as long as it won't contaminate the domestic water or cause a fire they are happy. Most important;y the inspection shall not interfere with the inspectors tee time!
3PSI gauge1 -
196 sq ft feeding 204 is perfect.
Why indeed
- 50 Industry Classes
