Steam Boiler Sizing, Small Home
13»
    mattmia2 Member Posts: 17,483
    edited March 2022
    Find out what residential code your city/township/county uses and look in the mechanical section. Look in the general or administration section at the beginning and look go see if there is a boilers section and look in there. You may have to go to a library, some codes are only available if you purchase them.
    Here are some examples from the 2015 michigan residential code:
    BirchLeaf
  • BobC
    BobC Member Posts: 5,570
    The codes pretty much confine themselves to safety, as long as it won't contaminate the domestic water or cause a fire they are happy. Most important;y the inspection shall not interfere with the inspectors tee time!
    Bob
    3PSI gauge
    pecmsg
    ethicalpaul Member Posts: 8,933
    196 sq ft feeding 204 is perfect.
    BirchLeafdelcrossv
    Why indeed
    I think if you read back through they did call a professional and it turned out that they weren't.
