"A bit of work in your apartment."
LOL. The guy new how to pipe though!!! Looks good!!!
Smile. Look at all the free heat they are getting!!
Now if they fir in the wall and ceiling it will be ok. They can move the stat and light switch out onto the new furred wall0 -
What is the end game here?
Move the switches?
Move the thermostat?
What are the pipes for?
So many questions from one picture.0 -
Yikes!
President
HeatingHelp.com0 -
Did they need to vacuum or anything when they got home?
The second thing I looked at was for mess / dust on the floor.
They took that pic as soon as they walked in.Retired and loving it.0
The quality of the work is still good.
Maybe the electricians didn't show upSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
DanHolohan said:I suspect they're gas pipes. I feel sorry for the electrician who has to get at that light switch if they're going to box this in, which I imagine they will.0
The electrician in me wouldn't be happy but it will be T & M so the owner will pay. The thermostat is a cinch.
The two light switches (and I am assuming they will box this in) they will just have to destroy some of the old sheetrock to get at the wire. It will be an ugly mess because the wires probably won't reach where they have to go.
They do have some new splicing gizmo's for romex that you can legally bury in the wall.
Or maybe the cheap owner will stud it and sheet rock it and leave too holes so you can reach in to get at the stat and switch LOL0 -
I'll bet they flip that box to the other side of the wall and use it as a junction box then extend the circuits to a new switch box in the new wall.EBEBRATT-Ed said:The electrician in me wouldn't be happy but it will be T & M so the owner will pay. The thermostat is a cinch.
If the sparky is 1/2 as good as the pipefitter, they will have it finished in no time. I would want to be a home for that one, here is no saying what the landlord will do next."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
@EBEBRATT-Ed ROMEX ?!?Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
What in Tarnation is going on here.
I'd be pitching a b**** fit over that.0 -
There's nothing wrong with NM-B wiring when used appropriately.delcrossv said:@EBEBRATT-Ed ROMEX ?!?
If you're planning on surface mounting it it across a concrete wall in a shop I'd recommend against it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
YMMV.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Are you in a different dimension or something where NM-B doesn't behave the same?delcrossv said:
It's literally THHN wire wrapped in a PVC jacket.
If code where you are doesn't allow it, that's fine, but it doesn't mean it's a bad product.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Not another dimension, Just Cook County, Illinois. No romex allowed.
I'm always bemused that it's allowed in multifamily structures elsewhere. Sure, it works fine, until a tenant puts a nail though it.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
You can put a nail through MC and BX as well.delcrossv said:Not another dimension, Just Cook County, Illinois. No romex allowed.
And EMT if you try even a little.
Same with copper pipes, pex etc.
As @Steamhead always says, you can't fix stupid and in those cases NM-B isn't the problem if it's installed in walls down the approx center of studs. When properly installed as per NEC normal picture hanging nails etc shouldn't be anywhere near NM-B.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Easier with MC, which is part of why it's not code here. IMO it's main attraction is ease of installation.ChrisJ said:
Some have used 3 1/2" nails for hanging pictures, they are certain they are driving it in the center of the stud. Wrong, just on the edge and at an angle coming out the side of stud into the cable. If it just penetrates the black (hot) wire then only the nail is energized, possibly the picture and wall (especially plaster) are "tingly".
GFCI and AFCI may trip.
But AC, MC and EMT with the metallic sheathing would most likely trip the breaker.
Rodents can have the same effect as the nail.
Squirrels (rats with pretty tails) like the NM sheathing on Romex. Have seen it in an attic, chewed down to both bare copper Hots on 240 V line, no dead squirrel near by.
So the metallic raceway wins out in these cases.1 -
Also, EMT or rigid conduit makes it easy to add circuits or replace decayed wire..Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Galv Rigid Conduit.JUGHNE said:It it GRC or RGC?
In either case fun to be had by all.....if T & M.
Have done enough of it to know I am thankful that EMT was developed.
I guess you can order it anyway you want.
I'll stick with NM-B where I feel it's safe and both PVC conduit and EMT where I feel necessary.
I'm very glad I don't live in an area that felt they needed to ban a perfectly acceptable product.
In the shop we use a lot of GRV.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Chicago has unusual codes because of the fire. In other areas the type of building usually dictates if romex is acceptable or not. Buildings that are smaller, easier to fight fires in and further away from other buildings usually can have romex.
Does the rent go down for the 3 ft^2 that they no longer have?1 -
mattmia2 said:Chicago has unusual codes because of the fire. In other areas the type of building usually dictates if romex is acceptable or not. Buildings that are smaller, easier to fight fires in and further away from other buildings usually can have romex. Does the rent go down for the 3 ft^2 that they no longer have?
If they are owners, does someone reimburse them for the amount their property was devalued? I know the answer, but stuff like this leaves me scratching my head.0 -
Chicago - Cook County is a good Union town, same in parts of Minnesota No Romex!! In spite of the fact its NEC approved and has been for years and years.
Can you name a house that has burned down because of it, and was installed to Code?
I seem to remember the Chicago fire being in the 1800's?Old retired Commercial HVAC/R guy in Iowa. Master electrician.2 -
Brass rigid conduit looks just like brass water pipe. Priced accordingly. Even around here, people just run galvanized rigid down to 3' below grade, put on an ell and run armored UM cable. I've only seen brass used for pool lights.
Aluminum is popular for service drops.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Lol. We call it zip cord.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Zip cord is called zip cord because it's easily separated like a zipper. Here, we call zip cord, zip cord.
So, not sure what to say.
Ha, ha, you made a funny.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 995 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
