no hot water
ncreek
Member Posts: 9
in Gas Heating
Lost hot water, i hear a fan running but have no ignition, cut off uniti at switch and turned back and unit goes though the motions , turn hot water on and nothing , fan stays running when cut water off
Can we get some more info? What type of water heater? Brand& model?0
Navien NR-240A LP0
Have you contacted the installer?Bob Boan
I installed it, im thinking the igniters are bad or flow sensor? Whats your take0
With any gas appliance....
Do you have gas? What is the incoming pressure? Are other appliances working?
Is the condensate draining? Could be the thermo fuse?0
what did the combustion analysis show?
did it work then stop or did it never work?0 -
It never worked and shows no fault code0
Draining fine,0
Gas on? That would usually throw a code tho0
Check static and dynamic supply and manifold pressure.
Any packing material in the vent like the clear packing tape over the little piece of cpvc to transition to PVC that htp shipped with my boiler?0 -
If you read other posts on this site, you will find that folks looking for help offer a lot more details. Pictures and responses using a few more words help us help you.ncreek said:Draining fine,
Normally I would wonder if the gas line is purged of air with adequate pressure or if the flow switch is closing the circuit.
The fan running all the time regardless of call for heat is a red flag. That sounds like a manufacturing issue. Have you gone through the troubleshooting part of the manual or called tech support?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
I havnt trouble shooted yet, havnt the time, was just looking to see if someone might of had the same issue, in gonna start with system pressure and the ignition Pin, with the fan running, if it is getting fuel then maybe the ignighter Pin is bad/ dirty0
how would the electrode be dirty if it has never run? i'd start with seeing if it even gets to the point of turning on the gas valve, might be a pilot then main stage, might just be a main stage. look at the sequence of operations in the manual and see how far it gets.
did you look in the menus for stored errors?2 -
The unit is 13 tra old and ive never had 1 problemi with it, never code or shows one now, thats whats got me stumped.0
Draft is fine, no obstructions, unit looks brand new inside0
the fan running is telling you
it tried to light and failed
it light but there’s other issues.Time to get it serviced.0 -
No this the first time ive had any problem with it, and it shows no fault code, i have serviced it regular. Idk0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
