no hot water
ncreek
ncreek Member Posts: 9
Lost hot water, i hear a fan running but have no ignition, cut off uniti at switch and turned back and unit goes though the motions , turn hot water on and nothing , fan stays running when cut water off
  • kcopp
    kcopp Member Posts: 4,630
    Can we get some more info? What type of water heater? Brand& model?
  • ncreek
    Navien NR-240A LP
  • Ironman
    Ironman Member Posts: 7,859
    Have you contacted the installer?
    Bob Boan
  • ncreek
    I installed it, im thinking the igniters are bad or flow sensor? Whats your take
  • kcopp
    With any gas appliance....
    Do you have gas? What is the incoming pressure? Are other appliances working?
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    Is the condensate draining? Could be the thermo fuse?
    mattmia2 Member Posts: 15,634
    edited February 2022
    what did the combustion analysis show?
    did it work then stop or did it never work?
  • ncreek
    It never worked and shows no fault code
  • ncreek
    Draining fine,
  • PC7060
    PC7060 Member Posts: 1,757
    Gas on?  That would usually throw a code tho
    Check static and dynamic supply and manifold pressure.
    Any packing material in the vent like the clear packing tape over the little piece of cpvc to transition to PVC that htp shipped with my boiler?
  • Zman
    Zman Member Posts: 7,611
    ncreek said:
    Draining fine,
    If you read other posts on this site, you will find that folks looking for help offer a lot more details. Pictures and responses using a few more words help us help you.
    Normally I would wonder if the gas line is purged of air with adequate pressure or if the flow switch is closing the circuit.
    The fan running all the time regardless of call for heat is a red flag. That sounds like a manufacturing issue. Have you gone through the troubleshooting part of the manual or called tech support?
    Albert Einstein
    Ironman
  • ncreek
    I havnt trouble shooted yet, havnt the time, was just looking to see if someone might of had the same issue, in gonna start with system pressure and the ignition Pin, with the fan running, if it is getting fuel then maybe the ignighter Pin is bad/ dirty
    how would the electrode be dirty if it has never run? i'd start with seeing if it even gets to the point of turning on the gas valve, might be a pilot then main stage, might just be a main stage. look at the sequence of operations in the manual and see how far it gets.
    did you look in the menus for stored errors?
    wmgeorgeIronman
    the fan running all the time makes me think it is failing to prove draft
    Zmanwmgeorge
  • ncreek
    The unit is 13 tra old and ive never had 1 problemi with it, never code or shows one now, thats whats got me stumped.
  • ncreek
    Draft is fine, no obstructions, unit looks brand new inside
    pecmsg Member Posts: 6,781
    the fan running is telling you
    it tried to light and failed
    it light but there’s other issues.
    Time to get it serviced.
  • Zman
    Now I'm confused...
    Albert Einstein
    Ironman
  • Zman
    Or this...
    Albert Einstein
    Ironman
  • ncreek
    No this the first time ive had any problem with it, and it shows no fault code, i have serviced it regular. Idk
  • wmgeorge
    wmgeorge Member Posts: 222
    What does this mean?? The unit is 13 tra old and ive never had
    Or this? I havnt trouble shooted yet, havnt the time
    Old retired Commercial HVAC/R guy in Iowa. Master electrician.
    Zman
  • psb75
    psb75 Member Posts: 1,101
    You need to use your words and language carefully. That is how we communicate on this forum. It's largely up to you to present information fully, and carefully. Otherwise WE CAN'T HELP YOU.
    Ironman
