Blocking UV
delta T
Member Posts: 884
So, I installed radiant tubing for a 5000 Sq ft slab, and the concrete has been delayed. Has anyone ever had to cover tubing to prevent UV damage? Anyone know what would effectively block UV? I don't thing regular 6 mil polyethylene sheeting does....maybe heavy plastic tarps?
Thanks for the replies everyone, the GC put down 6 mil black plastic to cover it. I have no idea how long the delay will be. There was a huge push to get the tubing in to pour the concrete, but now the concrete company is not pouring for some reason. Out of my hands, I warned both the owner and the contractor before I installed the tubing that UV exposure needed to be limited to 30 days as per the manufacturer (uponor HePex). Not really my problem, but I will be inspecting the tubing before they pour looking for signs of UV damage. In any case I am not going to warranty the tubing at this point. I've got 100 PSI on it at the moment. Can be frustrating some times.....
