Natural Gas Appliance/Range Flex-Line To Re-Position Awkwardly Located Mains Vent?
Jim_NY
Member Posts: 51
To get an air vent up and away from the main piping and between beams, have seen pictured here many creative routings - using nipples, unions, elbows, etc.
Looking up at an old, badly placed vent today, my cousin said "too bad you can't use one of those flexible stainless steel gas stove supply lines."
So in the spirit of fun speculation - besides expense and thread differences, could something like that work? Even long term?
As long as it didn't sag & make a trap, it should work; but there's now a spot on the wall of shame marked 'future picture of a gas flex line used to connect a steam vent'.
Seriously, if a flex line will work (no up&down that'll make a trap that'll hold water), so will pipe.
Thats the best education!Hap_Hazzard said:I say give it a shot. I love learning from other people's mistakes.
I'd use soft or hard copper and fittings. You could even go down and back up if you put a tee at the bottom and another tee at the main and connected them with a pipe downhill. I could see being able to come down over to the next joist bay and build an antler with something like this. The large tube carries the air, the small tube carries the water. Insulation probably would be a good idea too.0
A union or two can help with making avoiding having to rotate threaded fittings or solder too close to beams.
Flex for a non-intended purpose is a truly wild speculation. Have fun with them, but don't do it.0 -
You really know how to make me want to try something!
- 50 Industry Classes
