Natural Gas Appliance/Range Flex-Line To Re-Position Awkwardly Located Mains Vent?
Jim_NY
Jim_NY Member Posts: 51
edited January 2022 in Strictly Steam
To get an air vent up and away from the main piping and between beams, have seen pictured here many creative routings - using nipples, unions, elbows, etc.
Looking up at an old, badly placed vent today, my cousin said "too bad you can't use one of those flexible stainless steel gas stove supply lines."
So in the spirit of fun speculation - besides expense and thread differences, could something like that work? Even long term?
  • ratio
    ratio Member Posts: 4,264
    As long as it didn't sag & make a trap, it should work; but there's now a spot on the wall of shame marked 'future picture of a gas flex line used to connect a steam vent'.
    Seriously, if a flex line will work (no up&down that'll make a trap that'll hold water), so will pipe.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Could water puddle in the corrugated creases ? I would use nipples and 45's for good drainage
    Hap_Hazzardmattmia2
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    I say give it a shot. I love learning from other people's mistakes. :D
    pecmsg
    pecmsg Member Posts: 7,285
    Thats the best education!
    Hap_Hazzard
    mattmia2 Member Posts: 17,481
    I'd use soft or hard copper and fittings. You could even go down and back up if you put a tee at the bottom and another tee at the main and connected them with a pipe downhill. I could see being able to come down over to the next joist bay and build an antler with something like this. The large tube carries the air, the small tube carries the water. Insulation probably would be a good idea too.
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,137
    A union or two can help with making avoiding having to rotate threaded fittings or solder too close to beams.
    Flex for a non-intended purpose is a truly wild speculation. Have fun with them, but don't do it.
    ethicalpaul Member Posts: 8,933
    You really know how to make me want to try something! :joy:
  • JUGHNE
    JUGHNE Member Posts: 11,604
    Isn't there a mini tube steam system that uses copper?
    I would try soft type K, maybe 1/2" OD with flare fittings.
  • Jim_NY
    edited January 2022
    Well. This was fun!
    If he ever seriously meant to, perhaps I'd suggest he contact a professional - and I don't necessarily mean a steam-heat professional... :D
    Hap_Hazzard
    I think there is a brochure for it in the library.
