Easiest way to remove 1 1/2” skim tap 4-point square plug?
I prefer not to remove the sheet metal knock out around the plug to try and get a wrench on it.
I think the minimum frustration would be to remove the jacket even though it’s a pain.
1/2 inch drive 4 or 8 point socket, with an extension to get into the hole, and a breaker bar so you can wiggle the plug back and forth to break it loose. Or a 1/2 inch drive impact wrench. Measure the distance across the flats of the square, and order up a socket. 12 point socket might work. 12 point will not be marked with the size of the square across the flats, so just try a bunch of different 12 points (including metric), until you find one that fits.0
I'd use a 4-point ½" drive socket on a flex handle. Put a pipe hanger on one of the risers and secure it to the wall to keep the boiler from tipping, then you can stand on the flex handle until it gives.Just another DIYer | King of Prussia, PA
I would spray it with PB Blaster or such several times and rap on it with a hammer some.
You do not want to knock off the corners of the plug. 8 point socket fitting is critical.
Then use a 1/2 or 3/4" impact wrench .
The 18 volt 1/2" battery impact driver has done the job most of the time.0 -
I've said it a thousand times, but maybe it'll get through eventually. Penetrating oil does absolutely nothing when the threads have been sealed with a pipe joint compound. I've also found impact to be ineffective in breaking sealed joints. Sheer brute force is what it takes.Just another DIYer | King of Prussia, PA
It’s 16 degrees here in NJ Meadowlands as I write this.This boiler is for my tenants.
current train of thought is to spray the threads and rap the plug with a 3 pound baby sledge over the next few days, then attack on Tuesday.Then pound this 12 point 1/2” drive 32mn socket on (since apparently nobody has a 4 point) and try to muscle it.If not, I’m cutting the jacket open wide enough to get a straight wrench on it.Wish me luck.0 -
I don’t see any other skim options.I cut out the knockout. Socket made has good contact.Monday is the warmest upcoming day.I’ll pop it out then.Thanks for the input!0
Why in the world did you cut all that metal away, the panel is removable.Bodycount said:It’s 16 degrees here in NJ Meadowlands as I write this.
Leave it alone until the weather breaks. Break something now and you're in a world of hurt!2 -
1
The sheet metal around the plug is scored with a few spot welds.An angle grinder with cutting wheel made easy work of it.It will fit back in when done.0
Sure, if you have one, and a 4-point impact socket. Most people don't.JUGHNE said:It seems that a large enough impact is sheer brute force.
Or you could stand on a flex handle.JUGHNE said:You could buy the 4-8 point impact socket and rent an impact driver.
Also the more points on the socket the more chances of slipping and rounding off the corners.Just another DIYer | King of Prussia, PA
I’m going to try and locate the appropriate socket over the next two days. If not…0
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1
@delcrossv they don't come nearly big enough0
Somewhere in the 34 MM range works for me. Need impact socket and gun.0
Oops. Here you go:EBEBRATT-Ed said:@delcrossv they don't come nearly big enough
https://imperial-newton.com/impact+sockets.htm/inch/black-steel/075/4-point/deep/Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
@STEAM DOCTOR
Where do you get your 34mm 8-point impact sockets?All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
Or a 4 point hammer wrench.
https://imperial-newton.com/striking+wrench.htm/inch/offset/black-steel/4-point/Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
A drill bit and a sawzall is a lot cheaper.
I would bet a 30" cheater pipe on an 18" wrench will take that out. It will bite on the plug a lot better than a huge 3' or 4' wrench0 -
@EBEBRATT-Ed I don't think I even want to know what you'd need Beryllium sockets for. Or what they cost.
😨Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0 -
Gordo said:@STEAM DOCTOR Where do you get your 34mm 8-point impact sockets?2
I measured the flats with a caliper.1 1/16”.0
1-1/16" 075-1062-04S-B 3/4" drive, impact socket, 1-1/16" AF, 4-point, standard length, black finishBodycount said:I measured the flats with a caliper.
1 1/16”.
Per the link above. A 3/4 drive handle can be had for about $25 . Got mine on the clearance counter at the auto parts store.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
The trouble with these is you need an extension to get around the boiler controls, and with an extension you can't put your weight on the handle unless someone holds up the other end. A flex handle is just as strong and easier to use in this situation, unless you're planning to remove all the controls anyway.MikeAmann said:If you have access to one, you will want to use a sliding t-handle breaker bar so you can apply the force in equal and opposite directions. If necessary, use cheater pipes for more leverage.
Used a 32mm impact socket and it loosened up fairly smoothly.Installed 4” nipple, ball valve, shoulder nipple & a cap to prevent “accidents”.Now onto skimming it. Separate thread.7
You've been lucky so far. They're not always hollow.tommay said:Just cut the square portion off with a grinder or sawzall. This will leave you with an opening you can get a sawzall blade into and just make a couple slices down to the thread.
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
