Tenant overfilled boiler
Did they leave the fill valve on or is it leaking by?
Steam can leak through a tiny leak and never be seen. It just evaporates. Over fill the boiler and the leak shows up as water.
Why did the pilot go out? I hope the boiler is not leaking down on the pilot?
There is no control that will shut down the boiler because of overfilling unless it trips the pressure control.1 -
Some vents will not close on water too so it could have just come out of the vent. Could you see that water out the pilot out and where it came from? Some main vents also will not close on water so that is a possibility for the pilot.0
No they claimed to turn the water ball valve to fill it on and off shortly after. I suspect that because of their age they were just trying to keep the glass tube full at all times. I told them not to touch it unless the boiler shuts down. I live close so its nothing for me to stop by however one time this year it did shut down I think its from that lose rad. The leak was in a small rad upstairs and I snugged it up. I think that the water was escaping the system from there. No the water didn't put out the pilot to my knowledge. Although I couldn't believe how much that holds 12 gallons or so.The pressure control didnt work to shut it down at least when I got there it was still on. Maybe something faulty. The main vent isnt near the boiler and nothing was wet near it. I'm still somewhat confused and still worried that this might happen again....0
You should be OK, provided that water didn't carry gunk into a vent.
You could try educating your old couple -- in a very positive way -- as to what to look for on the boiler and where the water level should be. Being pre-World War II vintage myself, may I suggest that not all old folks are doddering idiots...Br. Jamie, osb
@Jamie Hall I'm going to replace some of the vents next week so I'll check them for blocks. I already went over and explained where it needs to be and not saying there are idiots they probably shouldn't be tinkering with the boiler as they aren't familiar with it.0
Just worried about it failing and a flood in the basement0
It's not going to fail. It's not going to flood your basement.hankwylerjr said:Just worried about it failing and a flood in the basement
O. M. G.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes2 -
Worry more about the washing machine hose breaking and flooding the basement. Copper pipes rarely break!hankwylerjr said:Just worried about it failing and a flood in the basement
2 -
I'll look into one provide I can install it myself. Plumber wanted $$$ to do it. Any recommendations on one for this unit? Old Peerless probably 15 years old under 200k btu0
We're not supposed to discuss prices here.hankwylerjr said:I'll look into one provide I can install it myself. Plumber wanted $$$ to do it. Any recommendations on one for this unit? Old Peerless probably 15 years old under 200k btu
That said that amount for parts and the time for a licensed, insured, trained, and experienced person to save you the hassle is not a bad trade off.
Just sayin'1 -
Seems to me you have several choices here. Decide the old folks can understand and maintain a boiler. You might be surprised. Decide to prevent them from ever filling it, and have them call you at oh dark hundred in a blizzard on low water. Have them decide to call their son-in-law, who is a lawyer, at oh dark hundred in a blizzard, who will get it fixed and sue you for damages. Find a good plumber and pony up to have an automatic feeder installed.
Tanke you pick...Br. Jamie, osb
You didn’t say where this rental is located but many jurisdictions require the landlord to supply minimum heat. Being an elderly couple may have other rules and regulations.Let the plumber install the feed valve.Consider getting a service contract.0
Take the handle off the feed valve?
I typically have 1 or 2 customers a year, whose feeder fails to seat properly. Fills boiler, rads.... I tell customers to avoid feeders unless they are in situations like this or if they travel in the winter.JohnNY said:Just worried about it failing and a flood in the basement
It's not going to fail. It's not going to flood your basement. O. M. G.1 -
Usually require you be licensed to do work in rental housing too.pecmsg said:You didn’t say where this rental is located but many jurisdictions require the landlord to supply minimum heat. Being an elderly couple may have other rules and regulations.
Let the plumber install the feed valve.Consider getting a service contract.2 -
Interesting comments re hoses to appliances. I have a Bosch dishwasher and the water feed is really unusual. There is fixed translucent host permanently connected to the appliance, this hose has some wires inside it. There is a valve assembly that connects to the supply bib. Seems to ensure that the supply hose is not pressurised when appliance is switched off! Work well enough until it goes wrong then the hose change is much more involved.
John
I second this recommendation.EBEBRATT-Ed said:Hydrolevel VXT is the best feeder. No reason you couldn't install it if you can sweat copper. You will need a backflow preventer as well
Make sure you install the isolation and bypass valves so the feeder can be removed for service without shutting down the boiler. Cutting this corner will come back and bite you every time.Just another DIYer | King of Prussia, PA
I see they are reasonably priced. Some on here know but those who don't know I pipe fitted for several years in my younger years and I should be able to sweat it and get it connected without much effort providing the wiring isn't too advanced. In our area a license isn't required to install a a feeder on our rental. Thanks for the help much appreciated0
- 15.8K Strictly Steam
