Canada has a realistic approach to
This is common in Europe also, Caleffi, for one has had products developed for piping hybrid systems for 5 or so years now. The valve shuttles based on outdoor temperature or based on time of day electricity costs.
See screen shots from a recent issue of Mechanical Business mag.
I could see banning it in new construction. That will force builders to build better where a HP can meet the demand at all temperatures. Also doesn't Quebec have really cheap electricity on par with NG?Robert O'Brien said:
My biggest concern with HP's is how destructive the refrigerant can be. r410 has like what, 4000x the heat trapping potential of CO2?0 -
I could see banning it in new construction. That will force builders to build better where a HP can meet the demand at all temperatures. Also doesn't Quebec have really cheap electricity on par with NG?JakeCK said:
New refrigerants are becoming available as HFCs are being phased out. Opteon claims zero ozone depletion, ODP and ultra low global warming potential GWP.
ideally the refrigerant stays inside the systems
That would be ideal, but after taking my old fridge and window ac's to a scrap yard, that told me they recovered all refrigerant, only to watch them use a backhoe to scoop them up... I'm less than optimistic.0 -
Yeah and some people still dump old motor oil in their back yards. Toss litter out their windows and in parking lots...Bob "hot rod" Rohr
Don't get me wrong, I still believe this is part of the solution. Just that we need better mitigation for old refrigeration systems.hot_rod said:Yeah and some people still dump old motor oil in their back yards. Toss litter out their windows and in parking lots...
I actually tried to have these old systems recycled responsibly. In Ohio its damn hard for a homeowner. Sure I could put them out on the curb for bulk pickup. As long as the fridge had the doors off. Perfectly legal and easy. Garbage truck comes and picks it up with the rest of the bulk and smashes it in the back. And all that refrigerant goes straight up into the atmosphere.
First Energy used to have a recycling program where they would pay you 50$ for your old appliances... The program was cancelled and the company they partnered with to recycle them went bankrupt years ago. I wouldn't even care about the 50$. Them picking it up and saving me the effort of carrying it out to my truck was worth it all on its own.0 -
Montreal had a bad experience when ice storm downed transmission to city.
QuebecHydro had paid homeowners to trash furnaces. So no heat even with a small generator sufficient to keep furnace going.
Regarding new construction issue is a bit about nothing but symbolism. Since late eighties Canadian houses are built to Canada2000 standards so they don't need much heating energy. Some are mostly heated with a heat pump ERV. Those tight Canada2000 homes require ERV. How much energy do they consume?0 -
It's high, but refrigerant doesn't matter if the house is planning for AC anyway.0 -
That is true.Hot_water_fan said:My biggest concern with HP's is how destructive the refrigerant can be. r410 has like what, 4000x the heat trapping potential of CO2?It's high, but refrigerant doesn't matter if the house is planning for AC anyway.
But one could argue that everyone getting ac has had an outsized contribution to our climates destruction too. Right there along with the automobile and national highway system.0 -
To run just a ERV? However much it takes to run a blower. Maybe between 50 to 300 watts depending on size? I wish my house had one. But no duct work and its as air tight as a sieve. The HP depends on heating load and size of the building.jumper said:Montreal had a bad experience when ice storm downed transmission to city. QuebecHydro had paid homeowners to trash furnaces. So no heat even with a small generator sufficient to keep furnace going. Regarding new construction issue is a bit about nothing but symbolism. Since late eighties Canadian houses are built to Canada2000 standards so they don't need much heating energy. Some are mostly heated with a heat pump ERV. Those tight Canada2000 homes require ERV. How much energy do they consume?1 -
But one could argue that everyone getting ac has had an outsized contribution to our climates destruction too. Right there along with the automobile and national highway system.Totally, but we have to meet people where they are. If they want AC, doubtful anyone can change their minds. At least the grid can be cleaned up quickly. Plus, where I live the heat kills and is only getting worse.0
Not disagreeing just stating my feelings on it being a race to the bottom.Hot_water_fan said:But one could argue that everyone getting ac has had an outsized contribution to our climates destruction too. Right there along with the automobile and national highway system.Totally, but we have to meet people where they are. If they want AC, doubtful anyone can change their minds. At least the grid can be cleaned up quickly. Plus, where I live the heat kills and is only getting worse.1 -
I live 20 minutes from the Canadian border in Maine. We saw a huge influx of Canada built pre-fab houses brought across the boarder back in the 90s when the Canadian dollar was weak and the US dollar was strong.
Many of those homes were setup locally, and I've worked in more than a few. I can tell that exactly 3 have had the ERV still plugged in.
Yes, they are relatively tight compared the much of the existing structures. But, all have conventional oil boilers and fin tube...and I do mean all. That was the rage back then.
They all consume around 800-1000 gallons of oil per season, on par with most other homes of comparable size here in climate zone 7.
So, I'm not buying all the super energy efficient stuff about Canadian housing. Granted this is modular housing in 2-4 sections, brought over on a truck and put together on site.
There are much better ways to build.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!1 -
Building and even hydronic codes seem more developed up north. I think current builds are fairly tight by code mandate.Solid_Fuel_Man said:I live 20 minutes from the Canadian border in Maine. We saw a huge influx of Canada built pre-fab houses brought across the boarder back in the 90s when the Canadian dollar was weak and the US dollar was strong.
Canada claims to have the cleanest electricity, 80% from non emitting sources, 58% from hydro.Bob "hot rod" Rohr
@JakeCK You're not going to be happy when I tell you my 1933 and 1934 refrigerators are still using their original refrigerants and that refrigerant has both 0 ODP and 0 GWP.It also works very well.
2 -
Old monitor tops? Why would I not be happy? Sulfer dioxide correct? It is amazing it is still working. But also back in the 30's they over built appliances. Today they engineer them with a MTTF in mind.ChrisJ said:@JakeCK You're not going to be happy when I tell you my 1933 and 1934 refrigerators are still using their original refrigerants and that refrigerant has both 0 ODP and 0 GWP.It also works very well.
I have even heard those things were actually more efficient than modern refrigerators from just a few decades ago. No auto defrost, ice makers, or other fancy gadgets, and thick insulation...0 -
sulphur dioxide? Propane is also pretty environmental I guess? I wonder how often somebody drops in fuel grade propane into R22 machine and then how often does a problem ensue.ChrisJ said:@JakeCK You're not going to be happy when I tell you my 1933 and 1934 refrigerators are still using their original refrigerants and that refrigerant has both 0 ODP and 0 GWP.It also works very well.0 -
There is quite a variety of refrigerants available. In fact, almost anything which has usable boiling point and condensing points within reasonable pressure ranges will work...
Problem is to find ones which aren't toxic or flammable or both.
On building codes and better or stricter here or there. Right. If rigorously applied, they may work well -- for new construction. What all the starry eyed types out there tend to forget is that there is a very large inventory of existing built construction, and a lot of their "solutions" are not helpful.Br. Jamie, osb
No, while we do have a few here that use SO2 that's most certainly a greenhouse gas with a high gwp.jumper said:
sulphur dioxide? Propane is also pretty environmental I guess? I wonder how often somebody drops in fuel grade propane into R22 machine and then how often does a problem ensue.@JakeCK You're not going to be happy when I tell you my 1933 and 1934 refrigerators are still using their original refrigerants and that refrigerant has both 0 ODP and 0 GWP.It also works very well.
Methyl formate is the one I'm speaking of.
@Jamie Hall my machines use both toxic and flammable refrigerants and it's really not a huge thing in my life except maybe during servicing.
See, they tend to stay in the machines especially if they're made correctly. Even after 80-90 years.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I do think Canada has a sensible approach to this. That said it is a frustrating thing that Maine...you know the state of a thousand lakes....has removed pretty much all of their existing hydro dams. And now we import Canadian "clean electricity" which comes from....you guessed it hydro.
We used to have many low head hydro dams here in my area some used to power mills, and were converted to electric in the 50s. Now they are all gone, and we have no generation left....other than incremental wind and solar, which is heavily subsidized.
And for the icing.....we got a state wide notice that our electric rates are going up 80% as of January 1, 2022.
I'll keep burning wood and using less than 200 watts to run my entire gasification boiler system.
I'd bet it's over 75% of mini-splits which leak out at least 1 full charge of r410a in their lifetime. I'm so sick of replacing outdoor coils.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
From what I've seen refrigerators, mini fridges, dehumidifiers, ice makers etc are all doing the same now.Solid_Fuel_Man said:I do think Canada has a sensible approach to this. That said it is a frustrating thing that Maine...you know the state of a thousand lakes....has removed pretty much all of their existing hydro dams. And now we import Canadian "clean electricity" which comes from....you guessed it hydro.
The days of hermetic systems going forever without a leak appear to be gone with everyone pointing fingers.
We're not allowed to vent refrigerant but manufacturers can do it all day long I guess.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
