rad noises
GW
Member Posts: 5,184
Gotta nice older couple in a new home, steam system is kinda blah, no main vents. Anyway I can't put my finger on the slight 'pinging' noises happening at the rads. It's like a very dull guitar string: it kinda 'pings' then there's an immediate trailing off sound (hence the guitar reference). It's not loud but it is certainly noticeable. Thanks for any tips
^^^ or a loose tension rod?Br. Jamie, osb
Sorry, I don’t understand a milk jug reference. But yes, pipe through the floor
also, the steam system is original to the house, then it was converted to a two family—-they yanked the steam on the first floor. Now, it’s a one family again, and the steam is only on the second floor. Boiler piping seems OK. boiler size seems OK.0 -
Pieces of milk jug, @GW . The plastic gallon size. They go under the feet of the radiator to help it slide across the floor as it expands or contracts. You can also use pieces of it to shim between the pipes where they come through the floor, if they are touching.
I guarantee nothing... but it sometimes worksBr. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England4 -
Ed the Radiators are pitching correctly. It’s not loud but it has a bit of a twang, I’ve never heard this before0
Thanks J I’ll pay more attention to the types of rads0
The one in my bedroom does this. I've contemplated tightening the tie rods to see if that helps, but the thought of breaking something scares me. lol Mine does it, to a lesser extent, when cooling as well.JUGHNE said:I have noticed that column radiators that are not connected across the top with nipples will "Ping" or "Clack" due to expansion as they heat up.
Once hot they are nearly quiet.0
- 50 Industry Classes
