rad noises
Gotta nice older couple in a new home, steam system is kinda blah, no main vents. Anyway I can't put my finger on the slight 'pinging' noises happening at the rads. It's like a very dull guitar string: it kinda 'pings' then there's an immediate trailing off sound (hence the guitar reference). It's not loud but it is certainly noticeable. Thanks for any tips
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • neilc
    neilc Posts: 3,213
    milk jug the feet and the pipe thru the floor?
    known to beat dead horses
    Jamie Hall Posts: 27,911
    ^^^ or a loose tension rod?
  • GW
    GW Posts: 5,257
     Sorry, I don’t understand a milk jug reference. But yes, pipe through the floor
    also, the steam system is original to the house, then it was converted to a two family—-they yanked the steam on the first floor. Now, it’s a one family again, and the steam is only on the second floor. Boiler piping seems OK. boiler size seems OK.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    Pieces of milk jug, @GW . The plastic gallon size. They go under the feet of the radiator to help it slide across the floor as it expands or contracts. You can also use pieces of it to shim between the pipes where they come through the floor, if they are touching.
    I guarantee nothing... but it sometimes works
    mattmia2Alan (California Radiant) ForbesGWethicalpaul
  • GW
    GW Posts: 5,257
    Ahh ok lil sliders.
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    EBEBRATT-Ed Posts: 21,190
    edited November 2021
    Ptch is the only thing I can think of but you probably checked that already
    GW
  • GW
    GW Posts: 5,257
    Ed the Radiators are pitching correctly. It’s not loud but it has a bit of a twang, I’ve never heard this before
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
  • JUGHNE
    JUGHNE Posts: 11,644
    I have noticed that column radiators that are not connected across the top with nipples will "Ping" or "Clack" due to expansion as they heat up.
    Once hot they are nearly quiet.
    GW
  • GW
    GW Posts: 5,257
    Thanks J I’ll pay more attention to the types of rads
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    mattmia2 Posts: 18,254
    You could try to make the run shorter, more frequent cycles so they don't heat and cool as much
    GW
  • KC_Jones
    KC_Jones Posts: 5,961
    The one in my bedroom does this. I've contemplated tightening the tie rods to see if that helps, but the thought of breaking something scares me. lol Mine does it, to a lesser extent, when cooling as well.
    2014 Weil Mclain EG-40
