Boiler
1bandit
Member Posts: 1
I turned on my boiler for the first time for the year and it won't heat up
That Sucks!0
Replace the batteries in the thermostat, if there are any.
Would be the first thing....then power switch or circuit breaker.
That is the most you can get here for just one sentence.
Same thing happened for a client of mine. I found out that a guy installing a dryer the week before had shut off the breaker for the boiler. That was a quick fix.0
