Today’s steam job
GW
Member Posts: 5,137
Plus a redo of some nasty gas mains
electrician shows up and after looking for the line voltage for 25 seconds, we’re like o snap it was a millivolt.😀
the copper drop with the feeder got repurposed, just tossed in a backflow
5
Pretty as a sweet-sixteen party!Retired and loving it.0
Utica out Utica in. Looks good!!0
Thanks guys long day and no lunch, I was hangry at the end of the day
Almost didn't pressurize the gas but i did, almost didn't skim the boiler but i did, almost didn't set the dips on the existing feeder but I did, all good now. 1 -
That water heater was the lightest 30 gallon tank I’ve ever had the pleasure of carrying. It was a featherweight.I race motorcycles in the spring, but this year I kept on going to the gym, there’s more to the story, but that’s the snapshotThe boiler is a 112. 2 inch toppings. i’m just reading the manual, I’m generally not adding more diameter and more risers than what the manual calls for. I realize that’s not cool with some of the steam folks.0
Ed yes we all get to drive our own bus. I’ve got things to do and people to see0
It's cool with me, puts you leaps and bounds beyond a lot of steam systems we've seen. Keep up the good work!GW said:That water heater was the lightest 30 gallon tank I’ve ever had the pleasure of carrying. It was a featherweight.
I agree I tend to stick with minimums too, with the exception of drop headers.... the drop makes the job go easier, so I figure the customer gets a better set up at about the same cost as not using a drop header. Also we use all standardized piping layouts for near boiler piping ( with a few rate exceptions). so sometimes they may get a big bigger header than is minimum, but it saves hours of piping layout and installation, so again customer comes out ahead without any real increase in cost. I looked at using Uticas as our lower cost boiler line since they really seem to last ( to replace the Burnham casting models that rot out so early), but they are no longer available in Chicago... only thier sister company Dunkirk and Dunkirks are now so expensive, that if you pipe them with the now required dual riser ( except the smallest sizes) they cost about the same as a Peerless.... so no go on the Dunkirks. We are using Slantfins now.
It's really nice to see even a small boiler that replaced like for like to actually get repiped properly... we almost never see that in Chicago. They just hack and slide leaving the messed up piping in place to cost the next owner thousands in extra operating costs. The Southside of Chicago is loaded with home sized Uticas and now they can no longer just hack and slide, so maybe the piping will now get upgraded.To learn more about this professional, click here to visit their ad in Find A Contractor.3 -
