Honeywell t-stat died
Patrick McGrath
Member Posts: 59
Hi all. It’s been a while since I’ve been here. My Honeywell TH8110U1003 is no longer showing anything on the readout (I did try changing the batteries). The display was getting finicky the past couple of years, so I am not surprised that it died.
Is there anything new out there for steam that works well, or should I just get another one of these? Thanks for any advice!
I recently installed a Honeywell TH8320R1003 VisionPro 8000 for my parents.Patrick McGrath said:Hi all. It’s been a while since I’ve been here. My Honeywell TH8110U1003 is no longer showing anything on the readout (I did try changing the batteries). The display was getting finicky the past couple of years, so I am not surprised that it died.
That one, or similar will do fine with steam.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Hi Nick - found the button battery inside, replaced it, no such luck. Thanks for the idea, though!nicholas bonham-carter said:There may be a coin sized battery which must be changed as well.—NBC
Ya know, I thought you might be joking around a bit, but this seems to be a fine idea. https://inspectapedia.com/heat/Heat-Anticipator-Ohms-Law.phppecmsg said:T87F!
It is a fine idea, @Patrick McGrath . And it's been around a long long time. Just about idiot proof, and it does a fine job of producing little or no overshoot or undershoot in the space temperature.Patrick McGrath said:
Do they still make the mercury switch version?0
That t-stat truly passed the test of time.Patrick McGrath said:T87F!
Ya know, I thought you might be joking around a bit, but this seems to be a fine idea. https://inspectapedia.com/heat/Heat-Anticipator-Ohms-Law.phpUnfortunately no longer made. I have seen them at yard sales.And I wasn’t kidding. Best stat ever.1 -
That would be nice, but no...mattmia2 said:Do they still make the mercury switch version?
