Honeywell t-stat died
Hi all.  It’s been a while since I’ve been here.  My Honeywell TH8110U1003 is no longer showing anything on the readout (I did try changing the batteries).  The display was getting finicky the past couple of years, so I am not surprised that it died.
Is there anything new out there for steam that works well, or should I just get another one of these?  Thanks for any advice!
    pecmsg Member Posts: 7,194
    T87F!
    Patrick McGrath
  • ChrisJ
    ChrisJ Member Posts: 17,485
    I recently installed a Honeywell TH8320R1003 VisionPro 8000 for my parents.
    That one, or similar will do fine with steam.
  • There may be a coin sized battery which must be changed as well.—NBC
    JUGHNEPatrick McGrath
  • Patrick McGrath
    Patrick McGrath Member Posts: 60
    edited September 2021
    1
  • Patrick McGrath
    Hi Nick - found the button battery inside, replaced it, no such luck. Thanks for the idea, though!
  • Patrick McGrath
    pecmsg said:
    T87F!
    Ya know, I thought you might be joking around a bit, but this seems to be a fine idea. https://inspectapedia.com/heat/Heat-Anticipator-Ohms-Law.php
    Jamie Hall Member Posts: 27,518
    pecmsg said:
    T87F!
    It is a fine idea, @Patrick McGrath . And it's been around a long long time. Just about idiot proof, and it does a fine job of producing little or no overshoot or undershoot in the space temperature.
    mattmia2 Member Posts: 17,217
    Do they still make the mercury switch version?
    T87F!
    That t-stat truly passed the test of time.
    Unfortunately no longer made. I have seen them at yard sales.
    And I wasn’t kidding. Best stat ever.
  • ChrisJ
    You already know the answer to that.
    That would be nice, but no...
