Impeller replacement
Hard to tell the impact directly. Maybe it would spin faster with less resistance and end up with the same characteristics?
Wondering if anyone has noticed the style change?
It may be "only one replacement part" but it isn't right. The geometry of the impeller is critical to the performance of the pump. Different geometry, different performance. You don't know what the impact will be, but it will be significant.
I agree with @Ctoilman .Br. Jamie, osb
@SweatyInToronto
Something sounds amiss. I would call Armstrong directly. Armstrong makes good pumps. The OD of the impeller determines the head pressure and the volume of water pumped. The width of the impeller determines the volume0 -
When ordering an impeller for a pump you need to know its proper diameter.
Jamie Hall said it right.
If you want to keep that pump you can get a larger diameter impeller and have trimmed to the right size,
it would be cheaper to replace the pump and do what Ctoilman said install a Taco 0010 cartridge pump.
jakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
I think that there used to be multiple companies called Armstrong selling pumps?EBEBRATT-Ed said:@SweatyInToronto
So maybe OP is looking at alternative universe?
Armstrong Fluid Systems is a huge company. Probably larger than a lot of the other companies. Headquarters is in TORANTO.
They are probably not as popular in the states as far as residential size pumps go (at least around here) although they do make them. They make huge pumps for the commercial and industrial markets.
I worked for two companies that (mostly) sold and installed Armstrong. Their pumps are as good as anyone else.
Difference is as far as I know they don't sell through plumbing & heating wholesalers but have their own network of factory reps
Thanks much. Enjoying the holiday weekend and haven't responded.
Besides the impeller I've put in for a sealed bearing unit. In retrospect, yes a new pump might have been a better idea. I'm from a long line of fix it until you can't, unfortunately perhaps.
But I will check around for a larger impeller though, and check with the Armstrong people. Didn't realize they are based in Taranta too, lol!
I worked in Toronto half century ago. One Armstrong company sold pumps that required Armstrong labeled motors and couplings. Rip off prices. In those days labor costs to hardware costs were opposite from today. So eventually attentive maintenance people wised up. Another Armstrong company's products looked like B & G. Which was the knock off or relabeled? Nowadays whichever is quicker to change out is way to go so I like the cartridge paradym. I'd even look into plug connections.EBEBRATT-Ed said:
Difference is as far as I know they don't sell through plumbing & heating wholesalers but have their own network of factory reps0
