Hepex used in chilled water applications
Solar_Hog
Member Posts: 2
Does anyone know what the cold limit is for hepex tubing? I have a water furnace that chills water and heats water. During the summer months I want to run chilled water but I don't know what the rating is for hepex or even if it can handle cold water.
Don't know for sure but your probably good down to +32 degrees0
upnor has an extensive manual about installation of hepex/aquapex, did you try looking at that?0
https://assets.supply.com/ul_pdfs/712593_ownersmanual.pdfmattmia2 said:upnor has an extensive manual about installation of hepex/aquapex, did you try looking at that?
Albert Einstein1 -
Steam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0 -
It just gets more and more rigid. I have used in applications where it gets well below freezing -- inside and out -- and other than not flowing much water when its frozen solid (!) it's fine when it thaws. I'd allow a little extra length, though, because it does contract and you don't want it to actually pull on a fitting.
I don't know what the brittle transition temperature is, but it has to be pretty low -- I've not seen evidence of brittle behaviour.Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 121 Chimneys & Flues
- 15.8K Strictly Steam
