Hepex used in chilled water applications
Does anyone know what the cold limit is for hepex tubing? I have a water furnace that chills water and heats water. During the summer months I want to run chilled water but I don't know what the rating is for hepex or even if it can handle cold water.
    EBEBRATT-Ed Member Posts: 20,469
    Don't know for sure but your probably good down to +32 degrees
  • Zman
    Zman Member Posts: 7,614
    Hepex is commonly used in snowmelt systems. Those systems get well below 0 degrees with no issues.
    Albert Einstein
    Canucker
    mattmia2 Member Posts: 17,461
    upnor has an extensive manual about installation of hepex/aquapex, did you try looking at that?
  • Zman
    https://assets.supply.com/ul_pdfs/712593_ownersmanual.pdf
    Albert Einstein
  • dopey27177
    dopey27177 Member Posts: 916
    Could only find this rating
    @160 psi 73F
    best to call the manufacturer
    Jake
    Jamie Hall Member Posts: 27,576
    edited August 2021
    It just gets more and more rigid. I have used in applications where it gets well below freezing -- inside and out -- and other than not flowing much water when its frozen solid (!) it's fine when it thaws. I'd allow a little extra length, though, because it does contract and you don't want it to actually pull on a fitting.
    I don't know what the brittle transition temperature is, but it has to be pretty low -- I've not seen evidence of brittle behaviour.
