Oil Line on Floor Protection
Captain59
Member Posts: 1
Yesterday I had a new oil line installed on the floor. In hindsight, I would have chipped away a trench in the exposed area and just covered it, but I didn't think of that. I want to protect the line that could get stepped on and kicked. Someone suggested putting concrete over it. I guess that would be like a little speed bump? Any tricks or advice on how to do this? Or, is there another option? Thank you.
A little speed bump will work -- but a couple of suggestions. First, slope the sides enough so you can roll a dolly or hand truck over it without great hassle. Second, if it were mine I'd slit a length of ABS drainage pipe the right length and, say inch and half or two inch lengthwise and slip it over the oil line, then make sure that that had an inch or so of cover on top...Br. Jamie, osb
Oil lines "Should" be in a corner where the floor meets a wall.
How was yours run?0 -
Sometimes chopping is much more easily said than done. When @Charlie from wmass reran the oil line for Cedric, it had to cross a section of floor at one point -- no alternative. He did it -- but it took a good chunk of a day to get a trench in all of 4 feet of that 90 year old concrete.Br. Jamie, osb
Jamie and Charlie need a bigger saw. These guys claim 8 feet per minute with their blade.
https://diamondkingtools.com/blog/how-fast-can-i-cut-through-concrete-feet-per-minute/
You Paying for it?WMno57 said:Jamie and Charlie need a bigger saw. These guys claim 8 feet per minute with their blade.
https://diamondkingtools.com/blog/how-fast-can-i-cut-through-concrete-feet-per-minute/0 -
A diamond wheel for an angle grinder will get down a ways and they are pretty cheap. The dust is horrific though0
The Skilsaw Medusa is my go to for precise and quick floor cuts.0
- 120 Geothermal
