Oil Line on Floor Protection
Captain59
Captain59 Member Posts: 1
Yesterday I had a new oil line installed on the floor. In hindsight, I would have chipped away a trench in the exposed area and just covered it, but I didn't think of that. I want to protect the line that could get stepped on and kicked. Someone suggested putting concrete over it. I guess that would be like a little speed bump? Any tricks or advice on how to do this? Or, is there another option? Thank you.
    Jamie Hall Member Posts: 27,551
    A little speed bump will work -- but a couple of suggestions. First, slope the sides enough so you can roll a dolly or hand truck over it without great hassle. Second, if it were mine I'd slit a length of ABS drainage pipe the right length and, say inch and half or two inch lengthwise and slip it over the oil line, then make sure that that had an inch or so of cover on top...
    pecmsg Member Posts: 7,236
    Oil lines "Should" be in a corner where the floor meets a wall.
    How was yours run?
    EBEBRATT-Ed Member Posts: 20,436
    Hopefully it is a protected copper line with the covering on it. Mortar is fine. You could also run it inside electrical conduit or pipe.
    Why dont you just chop next to it and put it in a trench?
    SuperTech
    Sometimes chopping is much more easily said than done. When @Charlie from wmass reran the oil line for Cedric, it had to cross a section of floor at one point -- no alternative. He did it -- but it took a good chunk of a day to get a trench in all of 4 feet of that 90 year old concrete.
  • WMno57
    WMno57 Member Posts: 1,408
    Jamie and Charlie need a bigger saw. These guys claim 8 feet per minute with their blade.
    https://diamondkingtools.com/blog/how-fast-can-i-cut-through-concrete-feet-per-minute/
    You Paying for it?
    edited July 2021
    A diamond wheel for an angle grinder will get down a ways and they are pretty cheap. The dust is horrific though
  • PC7060
    PC7060 Member Posts: 1,840
    edited July 2021
    The Skilsaw Medusa is my go to for precise and quick floor cuts.
